TheaterTek 1.5 - green line
Discussion in 'Desktop & Laptop Computers Forum' started by Julia, Feb 13, 2003.
  1. Julia
    Julia
    I've been very satisfied with the picture quality offered by TT 1.5, but all of a sudden for the past two days I had a thin green line appearing at the top of the screen.
    I wonder if anybody else had the same problem?
    I could not make it dissapear, and I would welcome any suggestions
    Thanks in advance,
    Julia
  2. ChrisAllenFiz
    ChrisAllenFiz
    Jun 14, 2002
    819
    +17
    I had a green spec down by my taskbar with TT1.5. It turned out that the taskbar was showing though the overlay. There is a setting in TT that allows the overlay to always be on top. Give that a try. Or try the forums at the TT website, which are very good,
    HTH
    Chris
