Theater Tek Simplicity
Discussion in 'Desktop & Laptop Computers Forum' started by Ken, Dec 17, 2001.
  1. Ken
    Ken
    Dec 15, 2000
    367
    Stoke-on-Trent
    +12
    I now have TT set to my liking. I initially had problems with video controls and syncing, that is now all gone due to reinstallation of everything, must have had something lurking in the background.
    Image is excellent and the sound is superb.
    Using a pronto I have stable and consistant results. It's the first time I have been able to simply turn on and insert a DVD and not touch a keyboard at all. Feels a little strange.
    The Aspect Ratio control is great, and being able to set movie start position makes future viewing painless.
    I now also use DVD Killer instead of DVD Genie I hadn't realised how perfect it is for TT, as all you want to affect is the Region Code.
    Pc Friendly (bit of an oxymoron really) and Interactual are still a problem, but that is easily fixed with the push of a button.
    I am now going through my collection, to set start position.
    Ken
  2. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Ken,
    Nice to see you now have TheaterTek working well.
    Could you post the spec of your PC, version of Windows etc ?
    Might help others in choosing the parts for a stable HCPC build for use with TheaterTek.
    Mark.
  3. Ken
    Ken
    Dec 15, 2000
    367
    Stoke-on-Trent
    +12
    Abit KT7E M/B
    Athlon 1Gb PSU
    Memory 256Mb
    Radeon 32 DDR with 7093 Drivers
    SB Live 5.1
    Toshiba 1502 DVD(barely audible)
    Win 98SE
    Regarding PC Friendly/Interactual, I just descovered this thread http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=99925
    and the tips by Andre & gmanhdtv, work perfectly.
    All I have to do now is put a DVD in the drive and relax, do you think I'll get bored having no distrations.
    Ken
    My Tip.
    Do the Tweaki first, then install Interactual, making sure you define TT as the defaut player, then remove and reinstall TT. Don't use the disc detect program because it will still try to load PCfriendly.
    Ken
