The YSP-5600 has been voted the best soundbar for 2016
Discussion in 'Soundbars, Soundplates & Soundbases' started by skk3, Sep 21, 2016.
  1. skk3
    skk3
    Sep 16, 2005
    2,542
    Rushden, Northamptonshire
    +245
  2. GaryB19722010
    GaryB19722010
    Sep 1, 2012
    6,046
    North East
    +3,840
    It was this or the 2700 for me, 2700 won only due to looks and more suitable for my other AV gear
  3. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,532
    +539
    YSP-5600 would be my preference, but not at its current price.
    Clem
  4. skk3
    skk3
    Sep 16, 2005
    2,542
    +245
    Yeah, too pricey by far...
  5. a5ian300zx
    a5ian300zx
    Jun 14, 2005
    3,549
    2
    North London
    +427
    I had a demo once and I have to say it sounds amazing, it's really did sound like the surround is all around you but you can't pin point it.
    Only downside is it can't do hdr.
  6. Gary_W
    Gary_W
    Jun 6, 2005
    450
    +21
    I've got one and I think it's great. Yes, it's expensive but considering where I couldn't put speakers, this was worth it. It does a very good job IMO.
  7. AudioVisualOnline
    AudioVisualOnline
    Well-known Member AVForums Sponsor
    Dec 4, 2008
    1,683
    116
    5 The Sidings, Bacup, Lancs, OL13 9RW
    +792
    Its certainly not the cheapest product, but when you consider it comes with a proper dedicated separate subwoofer, its using 46 drivers in the sound bar, and is using proprietary licensed processing technology to create that effect, you can see why it costs what it does. To be the best in class unfortunately does take a little bit of investment, but the results speak for themselves, there's no better sounding soundbar out there.
  8. dazm41
    dazm41
    Mar 19, 2007
    1,666
    worksop england
    +463
    whats stopping it from doing HDR will it ever do HDR ?
  9. Zbornak
    Zbornak
    Mar 1, 2010
    38
    UK
    +4
    I'd also like to know.
  10. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,532
    +539
    It is pretty lame offering a soundbar that can handle all of the whizzy new audio formats but not the video switching. The lack of passthru when in standby seems to be another gripe too, if I understand that correctly. My old YSP-4100 handles passthru when in standby, so it's not as if Yamaha don't know how to do it. Sounds like a hardware limitation somewhere, but it's not as if Yamaha couldn't have seen this as a requirement.
    My money is on a new YSP-5700 surfacing shortly, with HDR handling and proper HDMI passthru when in standby .....
    Clem
  11. a5ian300zx
    a5ian300zx
    Jun 14, 2005
    3,549
    2
    North London
    +427
    where did you get the info for the 5700 as I can't find anything on it.
  12. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,532
    +539
    I was speculating about a 5700! Yamaha followed my 4100 with the 4300, and the 2500 with the 2700, each time bumping the specs. just sufficiently to annoy existing users, leaving them feeling shortchanged. The 5600 follows the form factor of the older 4100 and 5100, which perhaps suggests that the larger format is required for Dolby Atmos delivery. I was suggesting that rather than address, if they can, any shortcomings with the 5600, Yamaha will simply just release a slightly revised model. In fact, if my speculation is correct then perhaps the revised 5600 will be the 5800, not the 5700.
    Clem
  13. killie77
    killie77
    Aug 19, 2007
    1,756
    Glasgow
    +173
    Ive recently bought the Yamaha 5600 and have been using the Bluetooth function with my iPhone
    until tonight. I did a Firmware Upgrade to 3.8 and appear to have lost the Bluetooth function.
    When i say lost when i press the bluetooth logo on the remote it has a message on the front panel saying Disable. Ive been in the settings and made sure Bluetooth is switched on. have also initialised through the advanced menu but no luck. Anyone have any ideas ?
    Ian
  14. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,532
    +539
    Power cycle, removing the mains power for 15 minutes or so might be worth a go. Failing that, try a factory reset. If you still have no luck then try your dealer and/or Yamaha.
    Clem
  15. killie77
    killie77
    Aug 19, 2007
    1,756
    Glasgow
    +173
    Thanks for the advice
    Powered it off at the mains for about 30 minutes. Still showing disable when I try the Bluetooth button on the remote.
    I've initialised it a couple of times through the advanced menu still the same.
    It was working fine with the iPhone until just after the firmware update. Not sure if that's just a coincidence. Will keep looking around and try and find a way to have the Bluetooth working
    Ian
  16. killie77
    killie77
    Aug 19, 2007
    1,756
    Glasgow
    +173
    Think I've fixed the Bluetooth Issue. Looking at the manual it appears that i had transmission ON instead of OFF in the Bluetooth menu. Seems to work now.
    But it's thrown up another problem I can only access the Mac Address in the Bluetooth menu. Before i could switch Bluetooth on and off and use the device search. I'm going to leave it as it is. As at least the Bluetooth seems to be working :)
