shotokan101
So what do you all think ? - It's doing my head in TBH
Try scrolling down on your 'home page' in flickr to reach the feedback links.. every time you think you're at the footer, it loads more results
Either I'm very unobservant and can't see the difference or I've had the "new" version for a while and have got used to the changes already.
To share you click on the rectangle with the arrow pointing to the top right, click on the drawing pin and pick your size then copy the text - I've had this for ages ?!?
Been using it since the beta came out, can't remember what the old version looked like anymore.
It gets the job done once you get used to where things are.
I've only been using it since the last version. One thing that really bugs me is that if you do a general search for photos and start to browse through them, one it takes ages to load the next 'batch' as you scroll down, but most annoyingly if you click an image to view it full screen and then go back to the 'search' page it takes you back to the top so you have to scroll through again and wait for them to keep loading again Has it always been this way?Flickr has never been the same since the original layout - loading times were snappy and navigation easy.
