THE ULTIMATE OPPO MEDIA DEVICE !
looun
Perhaps the most serious one is that it does not output higher than 48 kHz sound either via HDMI or optical. (?) In fact whatever changes one makes in the audio menu
what's do you mean? there is no movie with more 48kHz, only AKIRA have trueHD 192hz.
there are some music BD with 96hz .
audio menu is for analog output.
Tom2000
The M9702 as most mediaplayers can play HQ audio files: FLAC, WAVE etc. up to 92 kHz and 192 kHz (I have TB+ of such music files!). The audio menu provides settings for high-def. audio to output via optical output. The signal however that actually appears is downsampled to 48 kHz! Why?
Incidentally there is no analog output connection on the player!
theaxledentaldj
Or, this was yet one other clone limitation
rong did, I think I recall, because of some not exact h/w in the mobo or soc. Certain model revisions had it and didnt. Or was it his older firmware didnt support sacd.
Eitherway, I have SuperAudio ISO's, DVD-A ISO's with hi bit rate, HQ, HD audio. Everything is fully supported on my Oppo-203.
looun
There is no coaxial port only optical. (M9702 V3)
M9702 V3 ¿Como sacar salida coaxial? DIY
Tested the M9702 V2, optical output limited to 24 bits 96 KHz, coaxial allows 24-bit 192 Khz.
The limitation in the coaxial output at 192 khz comes by software, so the oppo makes downsampling to its maximum in superior files, tested with Mahler 5a in file 24 bits 354.2 Khz.
By optical only supports 96khz and so you have to mark it in settings or not get audio properly, will make noise and cuts.
Sometimes, depending on the format of the file when making downsampling to 96 khz produces cuts in the optical output (at least in my case to the water Dac)
For those who want to use the digital output (optical or coaxial) the reference is coaxial.
Tom2000
Thank you!
I am going to fix(solder) it and see how the home made coax works.
Regards
Poilaucul
The last few weeks I was watching all the GOT 4k ISOs and there were a few pauses but I was leaving it running and turning off the NAS. I've not seen that when just powering it and the NAS up and then watching a move right away.
Which protocol is the NAS using if you don't mind me asking? SMB v1?
Tanquen
It's set to SMB1 - SMB3. I think you have to have SMB1 for the M9702 to work.
The bigger issues are that I do not think HDR and Dolby Vision work correctly. I've had a few other movies with little pauses and it's random and restarting the movie or unit seems to fix it. I wish there was a more stable player.
I am interested in getting one of these players. I already have an Oppo 205 and would like to know which version would suit me best. I want to use the Oppo 205 just for my SACDs/music and one of these players to play my MKV files via USB 3.0 storage. Would getting the M9205 version be a waste just for MKV files?
Also, I assume that the loading speed for MKV files from USB 3.0 is the same as the Oppo 205 correct?
moremodey01
i would recommend another player personally for mkv , the loading time is pretty high, the overall gui is not that good (personal taste) and there is atm no support for dolby vision of any kind on mkv.
carlmart
How can I make an M9702 to Windows 10 PC interface work?
Do newer firmwares allow SMBv2 and SMBv3?
SMBv1 is too dangerous to use, because of ransomware and other perils.
theaxledentaldj
carlmart, the M9702 and basically, its Oppo-203/205 firmware will Not do SMBv2 or v3 ever.
You won't get any other UI to interface with any other OSes UI. You can try the Vero 4K+ with Kodi and the python stuff that moremodey1 has implemented here:
carlmart
OK, then tell me how can I use the M9702 safely on a network, because SMBv1 is not an option?
Can I use it with a Linux NAS system? What other options do I have?
chros
You can install NFS small server on Win10 as well, search in this thread for more info.
theaxledentaldj
Where can I find instructions or some kind of tutorial to work with NFS and M9702?
Check out AVPassions forum:
DVR-Provider thingy:
Tutorial Media-Server / Media-Center "DVR-Provider" lo mejor para tu Oppo 203, 205 y chinoppo (clones M9702, M9201, M9203, M9205) cineUltra 203, 204
Tutorial for Windows with NFS shares:
BadSector81
Hi all! I have one question plz help.
If you play a cropped HDR10 ts and use force DV, is it plays fine?
The black bars are grey or black?
I don't have DV capable TV so I can't check.
Thanks!!
Latest News
Roku announces new Streaming Stick 4K and OS 10.5
  • By Andy Bassett
  • Published
T+A announces high end 200 Series audio components
  • By Andy Bassett
  • Published
Trinnov Altitude update adds new features
  • By Andy Bassett
  • Published
Panasonic TVs welcome Disney+
  • By Andy Bassett
  • Published
Audio Research announces I/50 integrated valve amp
  • By Andy Bassett
  • Published
