Thomas Szucs
Established Member
Funny, the M9205 says Blu-ray when it is clearly not a disc player.
Does anyone know where I could buy the latest version of the M9702 at all? Preferably from a UK seller?
moremodey01Hi all the pics in the firmware are pngs and located in those files in /res folder:
image_bdp83.bin
image_kb.bin
image_mediacenter.bin
image_scrn_svr.bin
image_setup.bin
it is possible to extract them with this python script, fun fact it could be possible also to rebuild it as all are png and with a small patch in the firmware and the player exe to load alternative files and have kind of themes
Python:import mmap import os import sys import struct if len(sys.argv) != 2 or not os.path.isfile(sys.argv[1]): print("usage : %s image_xxx.bin" % sys.argv[0]) os._exit(1) with open(sys.argv[1], "r+b") as f: mm = mmap.mmap(f.fileno(), 0) num_img = struct.unpack("<L", mm[0:4])[0] print("num of images : %d" % num_img) basename = os.path.splitext(sys.argv[1])[0] for i in range(0, num_img): print("extracting image : %d" % (i + 1)) header_offset = 4 + i * 20 size_x, size_y, unknow_1, unknow_2, size, file_offset = struct.unpack("<HHIIII", mm[header_offset: header_offset + 20]) print("\timage size : %dx%d" % (size_x, size_y)) print("\tunknow 1 : 0x%x" % (unknow_1)) print("\tunknow 2 : %d" % (unknow_2)) print("\tfile size : 0x%x / %d" % (size, size)) print("\tfile offset : 0x%x / %d" % (file_offset, file_offset)) fname = "%s_%d.png" % (basename, i + 1) with open(fname, "wb") as dumpf: dumpf.write(mm[file_offset : file_offset + size]) print("\tdumped in %s" % fname) mm.close()
Emby?
Over at AVPassion forum, mod stated:
Comprar M9702, M9201, M9203 y M9205C Reproductores: Clon Oppo 203/205 (Chinoppo)
[QUOTE = "Tocinillo, post: 60372, lid: 2"] Nieuw antwoord van de verkoper. De spelers zijn vanaf 5 november beschikbaar (de drie modellen). [/ CITAAT] 5 november ready for sending? or only available?www.avpasion.com
"And when you see what we have achieved with Emby and Oppo (203, 205 and clones) you are going to love it. Stay tuned this weekend"
Emby?
dunno must be a python shell issue, i never used it , just install the one in the command line (type python and you ll get a redirection to windows store), or install WSL (linux) and use that one.moremodey01
I have installed Python 3.9.0, please tell me how to get the original picture?
Thanks!
Thank you very much, I saw the original picturedunno must be a python shell issue, i never used it , just install the one in the command line (type python and you ll get a redirection to windows store), or install WSL (linux) and use that one.
alternatively install the normal python in c:\python39 .
then
cd D:\AutoScript\res
c:\python39\bin\python extract.py image_xxx.bin
but to use a repacked img_xxx you ll need a patched firmware , most peeps dont care so i didnt bother
That would be what I prefer, but Im not going to go back to projectorsProjector users may prefer the full black effect like CXUHD. Hope the great moremodey01 can benefit everyone again. Thanks!
View attachment 1386648View attachment 1386649
Have you tried a factory reset.Hello,
I Am just after succesful jailbrake on my oppo udp 203 EU. Everything works fine, but I noticed that when i yem playing movie on blu-ray and then i unplug USB driver or hard disk The remote Control goes to limbo and i cannot do enything. The only button that's works is power button. So i have to turn off the player, then after rebutt everything works fine. This hapens only then when i AM Playing blu-ray/uhd, IT is normal thing or i do it something wrong ? Before jailbrake IT dosent hapened.
No, I have an 205EU. Did not even do a factory after jailbreaking. Have not noticed any problems since august when I did that.Yes, i do it by the book. You don't have this problem ?
Yes! Same problem occursJust try once again factory reset and it is the same when i play blu-ray and unplug usb from player the remote control goes to limbo.
Why do you need to unplug the USB when playing Blu-ray?
U sure ??Hmmmm....I wont sell just yet then! lol!
External subtitles have nothing to do with jailbreaking. The official version also cannot be unplugged during playback. This is basic common sense. You can use Android or other machines instead.Sometimes when you watching movie external subtitles from usb dosen't match so you have to download new one and unplug usb. Now when you do that remote controle goes to limbo... When you watching a regular movie it is ok you can press stop and then unplug usb safly form main oppo menu, but when you are watching a TV Series you have to press stop by the end of each episode to load external subtitles. Little inconvenient for me but I can life with that. More person can confirm that issiue with oppo UDP203 UE player after jailbrake to be 100 % certainty that is not some kind of bug ?
I tried four jailbreak versions and the problem was the sameWrong, multiple times i was unplugging the usb with external subtitles while playing original blu-ray on official oppo and nothing happens, no limbo no nothing
Really? It does happen on the official version? Was it something introduced from the Russian Jailbreak? Because I think I get part of the hanging issue you guys are talking about, but its something I can live with and at most times avoid. For me, I think, my Oppo doesnt like my NFS share files moving around too fast, renaming, deleting, and such and when I go back into file tree listing it gets stuck on the spinning gears and if I cant go back to home screen, I just use the power button off my oppo remote and then power back on. Its fast. And it refreshes my AutoScript stuff so I can add anything I want to my Favorites. This is all trivial compared to my experiences from owning an M9702, Popcorn Hour A100, C-200, A300 and the A400.I tried four jailbreak versions and the problem was the same
- 20xCN-60 requires activation
- 20xCN-65 requires activation
- 20xCN-65 free
- 20xRU-65 free
Only the official version that is not jailbroken can unplug the USB during playback, and the remote control will work.
No solution,You can only use the official version.
