The Two Towers EE Collectors Boxset Question
Discussion in 'Movie Forum' started by Indiana Jones, Nov 19, 2003.
  1. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,861
    Bristol
    +8,193
    I bought the The Two Towers Extended Edition Collectors Boxset yesterday that comes with the little statue and making of Statue DVD but I was wondering, someone told me that the 4 discs DVD Set was made of better material in the boxset than the normal set you can buy but is this true because mine is exactly the same as the versions not in the set
  2. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    i dont think its true of the TTT set - the packaging seems to be the same. but the fellowship set was much better in the collectors set than the non collectors edition (if you get my drift?)
    Gary
  3. Enigma
    Enigma
    Nov 30, 2001
    24
    Take a look at this link:
    http://www.dvdbulletin.co.uk/news/756
    It says in there, "These two versions will contain the same four discs inside, although the box set version will also boast lavish packaging..."
    You can take it that they mean the box as a whole is lavish, but I believe they mean the case the discs reside in.
    Gav
  4. Duvel
    Duvel
    Feb 15, 2002
    Northampton
    +3
    Packaging of TTT is indeed different depending if you go for the collectors edition with the statue or just the normal extended edition. If you look at the spine of the box the extended edition has a flimsy fold out flap, the collectors edition is a much sturdier design. Exactly the same difference as FOTR extended and collectors editions.
  5. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    Has anyone watched the extended version?
    Is it worth the extra £ and time?
  6. Fatti
    Fatti
    Oct 22, 2002
    665
    Worcester
    +40
    Is Gollum supposed to come out the box the way the bookends did in the FOTR boxset? If it is, it's stuck in pretty well.
  7. m000
    m000
    Sep 23, 2003
    124
    +9
    Its worth every single penny - The ending is much more complete - I dont care too much of the new tree beard scenes but the overall finish is soooo much better!
  8. Duvel
    Duvel
    Feb 15, 2002
    Northampton
    +3
    Had to get the Gollum statue out from the bottom. It is stuck in pretty well.
  9. Fatti
    Fatti
    Oct 22, 2002
    665
    Worcester
    +40
    I don't know whether it's stuck in that well so it doesn't come loose in the box, or he's just supposed to stay in there. I don't really want to knacker the box up trying to get it out.:confused:
  10. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    Bought it yesterday based on reccs. I had to destroy the box to get the gollum out....
    It is wrapped in polystyrene at the botton, which is held together by a cable tie and then the whole thing was glued into the bottom of the box.
    Not seen the video yet but my 8 year old went to bed with a gollum last night so that is the last I will see of that!
  11. docsmith2k1
    docsmith2k1
    Apr 20, 2002
    520
    Liverpool
    +17
  12. Jpfahy
    Jpfahy
    Classic :laugh:
  13. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,861
    Bristol
    +8,193
    Back to the main point, I went back to where I bought the boxset on wednesday and they had another set there and the outer box that holds the 4 discs is indeed made from a stronger material so I took mine back and they swapped it over, I didnt pay £40 for an incomplete set lol
