The Thing - X Box
Discussion in 'Nintendo Forums' started by Bam, Jan 14, 2003.
  1. Bam
    Bam
    Hi There..
    Could somebody help my son out, he's stuck on the above.
    He is up to the part where you use the computer and can see a man on one of the CCTV screens. There is a door with a keypad but don't know the code.
    What do you do next?
    Bam
  2. driver8
    driver8
    Nov 17, 2002
    191
    Malé, Maldives
    www.gamefaqs.com is a great site !
    Try - http://db.gamefaqs.com/console/ps2/file/thing.txt - this is the PS2 version; guessing it's the same ?
    Scattered around the room are 4 documents you can read for little tidbits of info, an adrenaline syringe and a PC. Use the PC to get the access code for the coded door.
    Good luck !
  3. Bam
    Bam
    Thanks but He's seen that, it must be different on the PS2 because this doesn't give a door code on the PC.
    Bam
  4. driver8
    driver8
    Nov 17, 2002
    191
    Malé, Maldives
  5. spidermanalf
    spidermanalf
    Oct 25, 2002
    1,987
    63
    Wakefield
    +103
    The number is on a whiteboard which you can only see while looking through the camera!!!
  6. Bam
    Bam
    Thanks spidy...
    Bam
  7. RimBlock
    RimBlock
    Nov 5, 2002
    530
    Singapore
    +15
    Ok,
    SPOILER...........
    Maybe I am just hopeless at games like this but.
    First Boss under the hanger.........
    The guides (which all seem to be a copy of the PS2 guide, word for word) tell me how I am meant to do it.
    I still cannot kill this boss.
    Can get in the room without getting hit, shoot all the targets on the Boss, kill the tentacles from the grate, shoot the little things btu cant get close enough to use a flame grenade without either getting hit or setting fire to it, the wood on the floor from the boxes and myself in the process.
    Oh and my health at entry to this room is only 50% due to all the masses of baddies in the Hanger and very little healing / no saves.
    I hang my head in shame but this has almost resigned a fun game to the shelf with the 'console conversions just don't play to well on the P.C.).
    Please help me resurrect the fun from this game.
    RB
  8. gamescam
    gamescam
    To the left of the boss should be a door. By this door is a box that needs fixing. You'll have to run up to it, fix it a bit, avoid the tentacles by running away, then run back and fix the box some more. Soon enough you'll have fixed it and you can escape - you don't even need to kill the boss.
    It's hellish hard though.
  9. RimBlock
    RimBlock
    Nov 5, 2002
    530
    Singapore
    +15
    It is at that.
    I have also noticed that after using a health pack and saving before going down the corridoor to the boss, if I reload then I have less health than I saved with (maybe a 5th -> 4tr less than the 50% I saved with).
    Would rather not have to start this chunk again as there is a long way back to the previous save :( .
    RB
