The story so far, advice please
Discussion in 'Cables & Switches' started by ianharvey, Jun 6, 2004.
  1. ianharvey
    ianharvey
    Dec 1, 2003
    57
    I have purchased:
    Panasonic 42PWD6 Plasma
    Denon 3805 Amp
    B&W VM1 (x5) Speakers
    Rel Quake Sub
    Denon 2900 DVD (ordered, not yet arrived)
    JS Scart to VGA Converter (for Sky +)
    I have some Van Damme cables for the Amp to Plasma component connection
    The big question is over cables!
    What do I need from the DVD player to the amp? Looking to spend £40
    What should I get for the speakers? I need 37 metres not including the sub, so I guess under £3 per metre is the order of the day! Sub is around 5 metres, so similar price would be nice.
    What should I terminate with to the speakers and to the sub (say £30 the lot)?
    Lots of questions, but I really don't have much of a clue at this point. Any help very much appreciated.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,432
    The Borders
    +2,593
    Hello Ian
    Simple - more VanDamme all round should work a treat.
    Soldered 4mm banana should do the trick for the speaker cables and the sub will be line level via RCA (unless it has line level XLR).
    Best regards
    Joe
