The Specific Challenge
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by gunizzle, Jul 27, 2005.
  1. gunizzle
    gunizzle
    Right, a bit of a dilemma,
    my bedroom is square with a small alcove which measures 136 cm long and goes back 46 cm deep, i intend to put a cabinet to fit flush with the wall and ideally it must be in maple.
    In an ideal world i would like to find a cabinet that fits the gap with a little room either side to get some speaker stands in but it cant stick out past the wall.
    Any ideas where i could get one? Ive looked at the Arco Nuevo cabinets on AV Sales but they are a bit pricey, the same with Blok, any ideas or suggestions would be very much valued as im running out of options an am getting the hump with it now!
  2. Cyril
    Cyril
    Jul 20, 2005
    1,113
    48
    +39
    Looks like you need something custom made.
    I have never used Jali.co.uk but they seem cheap!
    Kube designs in Bishops Stortford have good looking custom kit, but they are double the price of Jali.
  3. gunizzle
    gunizzle
    i live in Bishops Stortford so may have to check out Kube, but i just know ill end up paying for it!!
    DAMN!
