The RS232 of my Denon 3805
Discussion in 'AV Receivers & Amplifiers' started by xrzhang, Dec 29, 2004.
Tags:
  1. xrzhang
    xrzhang
    The Denon 3805 has a RS232 port. What does it use? Upgrade the software?
    BTW, how can I know the software version of my Denon 3805? Can I upgrade it? :lease: :lease:
  2. Calleva
    Calleva
    The RS232 port is for remote control via systems like AMX and Crestron - I don't think it allows software upgrades.
    The RS232 codes are available from the Denon USA website.
    Hope this helps.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,739
    London
    +1,075
    Can you check out your automatic setup results like the Pioneer AX5Ai using RS232?
  4. Rob100
    Rob100
    Nov 3, 2002
    3,469
    +227
    Nope...
  5. xrzhang
    xrzhang
    How can I check the result via RS232? What kind of softwares I can use?
    The Denon 3805 is my first AV receiver!
    :confused: :confused:
  6. S H A D O
    S H A D O
    Mar 16, 2001
    10,284
    United Kingdom
    +1,566
    You can't. Don't worry about. I've never used or had the need to use the RS232 port on my Denon ever.
