The Right Choice
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by mafridi, Feb 20, 2005.
  1. mafridi
    mafridi
    I have 3 options to choose from. My main use is HT music is 10% :
    1. arcam av8/p7, kef xq5,3,2c, arcam dv78 and kef psw3000 sub
    2. lexicon mc-4, cx-5, m&k s150 THX (all 5) + m&k mx-350 mkII
    3. meridian 568.2, 568v2, 598 DVD, dsp 6000, 5500c, 5000
    the meridian is ex-demo with warranty. the other equipment is brand new. the meridian is more than double the cost but is it justified. Can I look at any of them as a 5+ year investment?
    please help
  2. Big Adam
    Big Adam
    May 7, 2003
    527
    Peterborough
    +4
    May not help your decision but Superfi currently have 50 quid knocked off their usual PSW3000 price meaning it is now only 299.95. :eek:
    Offer ends Monday at midday.
  3. Smurfin
    Smurfin
    Aug 13, 2002
    21,466
    +4,399
    Finding someone who's heard all of that kit may be easier said than done; I've heard quite a bit of it - parts of each system really, and my gut reaction if movies really are the top priority is that the Lexicon/M&K setup looks superb. I know of several people who truly don't rate the Meridian DSP speakers, and the speakers on the Arcam setup are in a lower class.
    In fact looking at your kit, I'd say the Arcam/M&K combination would work extremely well, the Lexicon and M&K may be a touch harsh on the ears, depending on your listening environment. Speaking of which, what kind of environment are you using this kit in? i.e living room, dedicated room etc...carpets, soft furnishings?
    Also don't discount the Meridian G68J as it's the only one out of all the kit you've listed above that features room correction; not something to be sniffed at tbh.
  4. danny daniell
    danny daniell
    Jul 25, 2004
    1,849
    2
    +236
    Looking at those systems,it doesnt look like you could potentially go that far wrong with any of them.....they all look pretty well matched .It all boils down to what type of sound really floats your boat. If i were you ,i would try & arrange some auditions.
    Dan :)
  5. mafridi
    mafridi
    Hi thanks for your response. the room is marbled with very little furniture so the sound bounces alot. the guy has suggested some treatments to improve the acoustics which I will try. You say the M&K/Arcam is a good choice. How about the Kef reference 207 or 203 for fronts, 201 (rears) and 204C with the M&K Sub and the Arcam kit. The Meridian is really expensive and I could get the Arcam kit with M&K or the Kef reference much cheaper.
    still confused
  6. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    253
    I would look at the first setup, but with Velodyne sub instead of the Kef.
    Have you also considered a Rotel RSP-1098/RMB-1095 and a Denon 2910 with a Velodyne?
    Fish
  7. danny daniell
    danny daniell
    Jul 25, 2004
    1,849
    2
    +236
    The latest Kef Ref`s are great,but need v.hi quality amplification as they are very neutral/analytical,however,feed them properly & they are out of this world. I notice that your room has marbled floors so maybe wise to go for a processor with room correction.
    Dan :)
  8. recruit
    recruit
    Why worry treating the room when you could have Room EQ on the Meridian G68J it really does wonders for rooms with poor acoustics and it is approx the same price as the Lex MC4.
  9. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    990
    46
    +174
    I would imagine a room with lots of marble and minimal furniture will have problems with higher frequencies than that of the Meridian's Room Correction operating range. Auralex or similar would be a better starting point in this instance.
  10. Smurfin
    Smurfin
    Aug 13, 2002
    21,466
    +4,399
    Quite right Scott, but who in their right minds would want auralex in a living room with marble floors and minimal furniture? A processor with room correction (even if the Meridian can't correct anything really high, it can still do much of the frequency range) would definately be a good starting point.
  11. Peter Baker
    Peter Baker
    Sep 6, 2003
    656
    28
    LONDON
    +37
    Marble floors and M&K speakers soundslike a recipe for splashy screechy sound to me. I'd definitely try to listen at home before I bought that.
