The radio on my Zen micro doesn't work????
Discussion in 'Headphones, Earphones & Portable Music' started by deadred, Apr 15, 2005.
  1. deadred
    deadred
    Nov 18, 2004
    2,542
    71
    Cumbria
    +90
    When i try and listen to the radio it's practically impossible as it wont tune into any station, the only one it will pick up is the crappy local radio station! Also does anyone know how to add tasks to the calender on the micro?h
  2. CarlyTabitha
    CarlyTabitha
    I was thinking of buying a Zen mainly for the radio, would you recommend it then or have you abandoned trying to listen to it? I'd welcome your views
