The point of DVI?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bursar, Oct 30, 2003.
  1. Bursar
    Bursar
    Jun 29, 2003
    2,406
    63
    Cambridge
    +215
    Whilst out and about at lunch time, I popped into my local Seven Oaks.
    I asked if they sold any DVD players with DVI. After a kind of cagey yes, he asked why.
    I explained I wanted to hook it up to my Z2, and that I wanted to be able to output with the higher resolutions (720p).
    He was a tad confused at why I might want to do that, as apparently the image comes off the DVD in component form, so I'd be better off using component cables to the projector.
    He went on to say that the TAG DVD player they sell is upgradable with a DVI board, but he reckons the image quality is worse with DVI than with component.
    He also wasn't aware of the Samsung 935, Brainwave or Momitso players (but then I hadn't heard of the last two until recently).
    So is what he said true, and everyone who has hooked their DVD player upto their display with DVI has taken an image quality hit, or is he just fibbing because they only sell 1 DVI player and you need to get a second mortgage to afford it?
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Advantage of DVI is that it is possible to remove some digital to analogue and analogue to digital conversions within DVDplayer and display.
    The disadvantage is that you are limited to the quality of de-interlacing in the DVD player and also the scaling ability of the DVD player if it can do that.
    The TAG DVD player has DVI out when fitted with a PSM board. However it's not a direct digital connection to the de-interlcaing chip like it is in many other devices. TAG take the component analogue signal and digitise it (very effectively) before feeding that to de-interlacing circuits.
    Now, DVI can be used to transmit lots of signals. That doesn't mean that your chosen display will necessarily accept the signal your DVI DVD player sticks out. Indeed there are lots that are not particularily interested in locking on to [email protected] from DVI. I wonder how they are with [email protected] as well, guess we will find out soon enough.
    It's also worth noting that the DVI input of many projectors is designed for PC signals and the gamma on that input might be incorrect for video playback.
    Gordon
  3. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    But you are right, if your display has good scaling, and is compatible, DVI output should be better... :smashin:
  4. Warpaint
    Warpaint
    Jul 26, 2003
    597
    28
    Edinburgh
    +62
    Assuming that the projector is HDCP compliant, otherwise you will get no picture at all.
  5. Lefreck
    Lefreck
    Mar 27, 2002
    75
    L
    The Z2 is HDCP compliant. A nice side effect with my Epson TW100 is 100% overscan via DVI, so no more cropped pixels:D
  6. Bursar
    Bursar
    Jun 29, 2003
    2,406
    63
    Cambridge
    +215
    True. As mentioned, the Z2 is HDCP compliant, but it only matters if the player is HDCP. I think that the Brainwave and Momitso players are HDCP free (or it's an optional setting).
