The Philips DVD-RW. Is It worth £600?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Paul O, Mar 4, 2002.
  1. Paul O
    Paul O
    Nov 2, 2000
    481
    UK
    +21
    Have seen this for sale for £640.
    Do you think its worth it?
    Is it any good?
    The discs seem really expensive - anyone know if they are cheaper off somewhere on the Net?
    Or is it worth waiting 12 months for the next generation of players?
    Paul.
  2. Checker
    Checker
    It has time slip facility which is very Useful.
    Uses DVD-RAM, just record and delete, takes 3 seconds to delete.
    For perminant recordings you can use DVD-R and if you finalise will work on any DVD Player.
    I use 4-hour record and it is as good as Video.
    I use the DVD-RAM to record things like a TIVO, and DVD-R on standard 2-hour for Films to Keep.
  3. DaveP
    DaveP
    I found the Philips at about £685 and then thought about ordering it. I tried to find a cheap source of disks but that proved difficult.
    In the end I ordered the Panasonic. I primarily want to archive stuff off my Sky+ and my video collection so long term the cheaper DVD-R disks work out the best bet. The added bonus is using the DVD-RAM disk like the Sky+ with pause and play while recording.
    I've since found DVD+RW disks at about £10.50 each plus shipping costs. Thats a lot of money unless you intend re-writing them often.
    DaveP
  4. Paul O
    Paul O
    Nov 2, 2000
    481
    UK
    +21
    Thanks for the replys guys.
    The disks for DVD-RW are expensive - as I expected!
    I have seen the DVD-Rs for about £3.00, so I think that the Panny is more worthwhile.
    Hopefully that one will come down soon as well! I like the idea of a DVD-RAM and a DVD-R. Thats cool!
    Plus the Philips box is really big!! Why?!
    If it comes down in price then I'll get the Panny I think!
    Cheers!
    Paul.
  5. DaveP
    DaveP
    I forgot to say I got the panny at about £700 inc P&P. I think they are being disposed of cheap because the next model is due out soon. I think the list price of this will be close to a grand again tho'.
    I took the gamble and bought now. They may come down further but that's a gamble too.
    DaveP
  6. ROne
    ROne
    Dec 21, 2000
    781
    +8
    The philips recorder well I was a lucky one who paid £1000 for it not long time a go.
    Its a great machine - in principle - but we are in firmware hell at the moment and are waiting for updates to fix stuff here and there - gulp (this ain't no tesco special but a thousand pound machine that can't play some R2 discs).
    However burnings great - DVD+RW is for me a better format than the others . I have had 75% success with discs done on this machine and then played on other players, and shortly there will be the DVD+R which will mean cheaper discs with write-once capabilty shoud you need it.
    You can get the +RW discs for about £7.00 plus vat if you buy in tens but they did start out at £15 so things are moving.
    rone.
  7. PeteM
    PeteM
    Jul 14, 2000
    95
    Maidenhead
    +4
    Personally I'd wait and look at the forthcoming Sony player. It can apparently support both +R, +RW, -R, -RW so is reasonably futureproof - you just buy whatever blanks happen to be cheaper.
    Also if / when one rewrittable flavour falls by the wayside, you are likely to find that the supply of blanks for that version get very expensive in relation to the other - or worse still become unavailable.
    I'd also avoid DVD-Ram, I see this as the weaker of the 3 formats.
  8. encaser
    encaser
    Mar 15, 2001
    2,161
    Suffolk/Essex
    +417
    Worth bearing in mind that blue laser models are to appear in the US next year with 27gigs a disc capacity, so if you can fight the urge to buy...
  9. Paul O
    Paul O
    Nov 2, 2000
    481
    UK
    +21
    £700 isn't bad for the Panny. I think £600 is a realistic threshold though. Anything more than that for a fancy video recorder is a little bit steep.
    I have a feeling that Philips version of DVD-RW won't take off long term, it doesn't seem supported. Plus what ROne said about the problems makes it a bit of a caution (Plus its massive! Anyone know why?!).
    I like the idea of DVD-RAM, although I also see it as probably the weakest of the lot. However, if its coupled with DVD-R capabilty also, then it makes for a great "free" option.
    Meethinks that DVD-R will be the one that takes off, with one of the RW's been the distant second. Similar to CD-Rs really. Many still don't support RW.
    The blue-lazer tech is pretty nifty, but I think that will launch over here in about 2004, and start at a grand again, 2006 before its affordable.
    I think that, if I can keep my credit card in my pocket that long, that it would be wise to wait for the next-gen machines and see what they offer. Plus surplus stock of the old stuff will drop in price too. Bargain!
    Crazy format-war stuffs!
