The Panasonic Plasma FAQ Thread
Discussion in 'Panasonic TVs Forum' started by Alexg, Mar 14, 2005.
  1. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    Seeing how popular they are and loads of questions being asked about the Panasonic range of plasma screens (mainly by me) I think its time we had a STICKY with the frequently asked questions on them to save all the searching and all the new threads asking previously covered questions. If others could add some more info that would be great.
    I'll start off with the model differences (sourced from another thread)
    Differences between the PW & PWD models
    Casing:
    PW (Consumer): Available in silver.
    PWD (Business): Available in charcoal and silver, charcoal being very easy on the eye and is good for home cinemas.
    Radiation:
    PW (Consumer): Class "A" means less electrical interference.
    PWD (Business): Class "B" but no problem at all having it in your home.
    PIP/PAP/POP:
    PW (Consumer): Single digitizer.
    PWD (Business): Twin digitizers, so that using the Twin source feature (PiP, PaP, PoP) is less restricted in what sources you can mix on screen.
    Accessibility:
    PW (Consumer): Standard menu options.
    PWD (Business): More advanced menu options for setting up the image, good for those looking to get the best image out of the set. But be careful with the settings.
    Warranty:
    PW (Consumer): Consumer warranty.
    PWD (Business): Consumer or business warranty depending on place of purchase.
  2. Bearded_Malc
    Bearded_Malc
    Aug 10, 2004
    393
    +20
    It would also be useful to mention some of the flaws too, so that people can make an informed decision.
    No 50Hz HDMI
    No colour control for RGB signals (i.e. saturation is not adjustable, white balance is of course)
  3. Andrew_P_S
    Andrew_P_S
    ....and some of the benefits (for an equally balanced assessment)
    Class leading picture quality!!
  4. jwillans
    jwillans
    I'd really be interested to read the differences between the PW6/PW7 range.
    Thanks.
    James
  5. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    press and hold volume - (minus) on the panel then presss status on the remote button 3 times (this is the button beneath the standy button).
    I think this is a very good idea if we keep it to facts as opposed to subjective views about pq etc which are covered in mind boggling detail elsewhere :smashin:
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    service menu for PW6 and PWD6 as well as PW5 is same as above and the PLasma FAQ has two links that cover almost all you need to know.....
