The Others - Region 3 DTS
Discussion in 'Movie Forum' started by I J S, Jan 29, 2002.
  1. I J S
    I J S
    Just seen on www.dddhouse.com that they are now stocking The Others DTS R3 version for roughly around £7.With shipping you are looking at just less than a Tenner which seems extremely good value.
    Whilst browsing their site I also noticed that they have The Gift DTS for $40 HK Dollars (Roughy £3.50) which is very cheap indeed.
    One or two bargains to be had over there.
    Ian
  2. encaser
    encaser
    Mar 15, 2001
    2,819
    Suffolk/Essex
    +740
    Have you bought from there before? Had a mate from HK at Uni and he warned me about dodgy copies with dif to what expect on.
    Never know though, some UK are total merchant banker outfits.
  3. I J S
    I J S
    Yes I bought Shaolin Soccer and Battle Royale which were both genuine R3 DTS versions.I think it's the Region 0 stuff they sell that you need to stay clear of!
    Service wise they have been excellent.Just around 7 days for delivery!
    Ian
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    You should also be aware of R3 DVDs, some are copies of R1 (i.e. re-coded), some are properly mastered while others are not.
    Usually can only tell from looking at the packaging or labels, a bit difficult when you do mailorder ...
  5. Ono
    Ono
    Oct 18, 2000
    1,612
    London
    +215
    DDDHouse are a great company.
    I have ordered loads from them and not had a single problem.
    The reason they are so cheap is because the Hong Kong DVD releases HAVE to be cheap to compete with the VCD piracy market.
  6. Rambo John J
    Rambo John J
    Aug 11, 2000
    4,893
    Hanoi Hilton
    +2,008
    Plus the fact that the HK currency is worthless - always nice for the UK punter.
    I've used dddhouse a lot and they're a great company
  7. Ten
    Ten
    Jul 1, 2001
    163
    16
    UK
    anyone had problems ordering from dddhouse, have not used them before, but can't seem to get it to process my order. i select my disc, go to buy dvd, select shipping country but thats it, i get to the recalculate page but my disc is missing. is there something simple i am missing?
