The Others DVD R1 - With DTS ?
Discussion in 'Movie Forum' started by Russ, Apr 30, 2002.
  1. Russ
    Russ
    Aug 3, 2000
    214
    Warwick, UK
    +16
    I cannot work out whether this disk will have DTS or not !
    Play247 show DD5.1, but DVDplanet (for example) show the disk with DTS.
    If you look on the official 'The Others' website it states DD5.1 !
    Any ideas ?
    Russell
  2. Bone Daddy
    Bone Daddy
    May 1, 2001
    502
    west midlands
    +3
    Seem to remember reading somewhere last week that DTS has been dropped from this one :confused: and that a super edition would be on the cards somewhere in the distance,this seems real stupid cosidering it is a double disc so they cannot get away with the old excuse of not enough space left for DTS,anyhow still have it on order and will have to wait for it to arrive and see if it is on there - it might be as I don`t think it has been confirmed yet,although someone may step in to put me right on that one.
  3. juboy
    juboy
    There may have been some confusion with The Others DVD as it came out first on Region 3... and that DID have a DTS soundtrack included.
    A number of UK mags reviewed this disc, which many may have thought to have been a Region 1.
    The Region 1 release does NOT have DTS. Apparently the DD 5.1 track is scorching anyway though. As for a special edition, it's possible but what can they really add other than the DTS soundtrack?
  4. Russ
    Russ
    Aug 3, 2000
    214
    Warwick, UK
    +16
    Try this reference just to confuse things then !
    http://www.dvdplanet.com/product_listing.asp?productid=23447&format=DVD
    [The Others (Special Edition)]
    I also use DVD profiler and thier database has two R1 versions -
    UPC 65935-14115 from Miramax,Dimension (DD5.1 with french
    and
    UPC 17232-02348 from Disney, Buena Vista )(DD5.1 and DTS)
    (Where do they get this information from ?)
    Maybe things have changed and web sites have not been updated !
