The Original Prob Forotton Pin
Discussion in 'Satellite TV, Sky TV & FreeSat' started by smithaaron, Jan 12, 2005.
  1. smithaaron
    smithaaron
    hi.
    i know this is the original problem but ive searched everywhere on the forum.
    Anyway i have forgotton the pin number for my sony VTX-800U, there surly must be a way of resetting something or a special code ypu put on the remote? i cant retune my freeview box to pick up the changed channels. Arrrh.
    Of any1 can help i will be absolutly on my knees
    cheers and thanks lot
    a. smith
  2. rcanter
    rcanter
    I am in a similar position that you were in, hopefully you have resolved the issue of getting past the pin code. I am also rather desperate. If you know of the process to reset the pin code for the Sony freeview thing, please could you share it with me.
    Ross
