THe old viewing distance Chestnut
Discussion in 'General TV Discussions Forum' started by jdoherty76, Oct 12, 2017.
Tags:
  1. jdoherty76
    jdoherty76
    Jan 11, 2006
    81
    I’m sure this is the age old question. I have just completed revamping the main room and want to put a TV on the wall. My budget is £1,000 (not much considering the price of some of the TV’s out there). This issue I have is that the viewing distance will be approx. 13ft and I’m not sure what size of TV to get to accommodate this. I understand that bigger maybe better, however I want it to look aesthetically pleasing and not a monster on the wall. I have seen a 65Inch Toshiba, a 60 inch LG and a 58inch Panasonic all within this price range. I’m not sure about the quality of the Toshiba as I believe they are made by Vestel in Turkey. So I’ve no real reference to go on. Any advice would be appreciated. Thanks JD
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,898
    Norfolk
    +2,535
    Aesthetically it depends on the scale of the other fixtures and fittings in the room. If you've got big windows, a big fireplace and 2.5m ceilings then 65" will look pretty modest. If everything else is barely 2' wide then it'll look far larger.
  3. Khazul
    Khazul
    Sep 10, 2017
    1,847
    3
    2
    116
    UK
    +672
    Have a look at this -
    TV Size to Distance Calculator and Science
    Once past 9-10ft its basically a case of get as big as you can afford / have room for.
    By 13ft even a 100" projector screen probably wont seem that big and a 65" 4k screen probably will not look any different to an old 720p.
  4. AndyRg4
    AndyRg4
    Mar 29, 2014
    550
    43
    Plymouth
    +102
    Bigger is better as people say but out of the 3 brands listed, the Panasonic would be my choice because of its superior picture
  5. raymondo77
    raymondo77
    Aug 14, 2013
    6,054
    3
    Reading, Berkshire
    +8,772
    I'm 12' from my TV and it's definitely as small as I can cope with at 65", as I want my image to be as cinematic as possible (projector is out of the question before anyone pipes up).
    If I could afford it I'd be pushing for 77".
    For reference this is what 65" looks from my seating distance (photo taken on a mobile).
  6. jdoherty76
    jdoherty76
    Jan 11, 2006
    81
    Thanks to all. It's the cash element. I know I can get a 65 inch Toshiba TV from Costco for £850 the rest would be far too expensive I'm afraid...I agree thought I have large bay windows (opposite end) and 2.5mtr ceilings with a drop to just under 2mtrs where the wall the TV would go on..
    Any thoughts on Toshiba? as a TV
  7. AndyRg4
    AndyRg4
    Mar 29, 2014
    550
    43
    Plymouth
    +102
    If you are considering Toshiba, I would instead look at Hisense. As you mentioned before, Toshiba TVs are made by Vestel and are adequate at best really.
    Hisense on the other hand, whilst still a lower end brand, are really making an impact on the UK market. I can quite honestly see in a few years Hisense being up there with the likes of Sony, Panasonic, Samsung and LG.
    I can remember, not that long ago in all reality, where Samsung was considered a more budget brand against the premium Sony and Panasonic. Look at them now however and they are one of the biggest brands in the world.
  8. jdoherty76
    jdoherty76
    Jan 11, 2006
    81
    Thanks Andy that's good news as Richer sounds do Hisense with a 6 year warranty..
  9. jdoherty76
    jdoherty76
    Jan 11, 2006
    81
    What about an LG at 60 inch's that curry's are currently selling.. how does this compare to Hisense..??
  10. AndyRg4
    AndyRg4
    Mar 29, 2014
    550
    43
    Plymouth
    +102
    LG use IPS panels in all their LCD TVs which give very wide viewing angles (probably not a concern giving your viewing distance) but have mediocre black levels, meaning contrast isn't very good (especially if you like to watch movies in lower light levels).
    I recently went on a holiday to Florida and in the villa they had just installed a 65" Hisense 4K TV. Obviously out of the box it was a bit garish, but I put it in the cinema picture preset and tweaked the picture a bit and was actually quite impressed with the picture. I use one of the best 1080p LCD TVs made at home (Sony KDL55W905A) which can stand its own against many of the 4K TVs made today, but the Hisense I would have been quite happy to own given its price
  11. jdoherty76
    jdoherty76
    Jan 11, 2006
    81
    thank you for an honest opinion..
  12. NicolasB
    NicolasB
    Oct 3, 2002
    6,694
    137
    Emily's Shop
    +1,071
    Does it really have to be wall-mounted? You could ease viewing-distance problems by having it closer to you, on a table.
  13. jdoherty76
    jdoherty76
    Jan 11, 2006
    81
    Cheers Nicolas afraid everything has been set up for wall mounting. The best of both worlds. Keep the missus happy..
  14. Khazul
    Khazul
    Sep 10, 2017
    1,847
    3
    2
    116
    UK
    +672
    If you have concerns over screen size in the room - tape a bunch of black bin liners together to approximate the TV size and tape to wall with masking tape to see how a big slab of black looks :)
  15. jdoherty76
    jdoherty76
    Jan 11, 2006
    81
    Good thinking Khazul thanks..
  16. cooperda
    cooperda
    Sep 26, 2005
    1,061
    Greater Manchester
    +146
    Well with my 4K TV 50in I sit no more than 6 feet away - so at 13 feet - I guess 65in TV if your budget allows
  17. jdoherty76
    jdoherty76
    Jan 11, 2006
    81
    Thanks Cooperda think I'll need to dig a little deeper and get the bigger screensize
  18. jdoherty76
    jdoherty76
    Jan 11, 2006
    81
    I see a Hisense and LG 65 inch for £1,099 I'll just need to compare them..I've already had some good feedback about Hisense..
