55"650
Set number 3 turned up (must say Currys have been excellent in all this TBH and would use them again), November build (don't think this means anything) and it was un-opened
Colour out the box was better then the oct build I had (wife said it straight away), not sure about the other Nov as it was a brief encounter.
The red is better as I needed to run +15 on red tint before, but not on this set. Not that the Oct was worse, it just needed abit more work to sort the red.
Banding!!!!! It still has vertical banding, but it is alot better then the other two (Oct,Nov). Instead of having 15-20 thin vertical bands it has a few wider ones. These are less noticable TBH and I will probably keep this set, don't want to risk it again. I also feel sorry for Currys having to deal with LG's issues, but they assure me they go back to LG for replacement NOT back into circulation. I think LG might be dressing them and sending them back to Currys etc.
Light bleed is fine as it was on all 3.
I checked my mums two Sony (non led) tv's on the football @ lunch and they both had banding, so feel you have to be very luck to get a perfect one esp. on 55".
Could be wrong, but I'm sure this set has a tad more colour depth, this maybe associated with the fact that the RED tint is different so maybe something is!!!! Both running 5???? software and my wife (who doesn't normally get involved) just said she thinks the picture is better. I'm seeing better purple colour and deep, deep colours.
Very impressive screen, if you can handle vertical banding (some more some less) which if you can't you need to go or stay plasma.
The 1920x1080 strickly final (all others were 1440x1080) looks amazing - cant wait for OLED.
