the new nad htr-2 universal remote ?
Discussion in 'Home Cinema Control & Remote Controls' started by grahamd, May 20, 2003.
  1. grahamd
    grahamd
    Jul 4, 2002
    73
    norfolk
    has anybody got any comments on this remote, good or bad.
    on paper it sounds ideal for me and only £45 from hifibitz.
    it will be controling sony 44px2, yamaha processor, thomson dtt, panasonic vcr, arcam cd.
    also, does it have fast text buttons.
    tia.
  2. bugfinder
    bugfinder
    Graham
    I'm also very interested in this remote - seems a bargain!
    To control:
    Loewe Aconda
    Sony DVP-S325
    Yamaha DSP-E800
    NAD c370
    Marantz cd6000ose
    If you get one or find out any more on this then please report back. I'll do likewise.
    Dan
  3. bugfinder
    bugfinder
    Have bought one and can definitely say it is a quality bargain at £45 from Hifibitz. I have retired 6 remote controls thanks to this bit of kit.
    Arguably the only thing it misses are the 4 colour fast-text buttons, but there are more than enough buttons to work around this.
    It's very easy to set up and use, all the buttons are back-lit so easy to use in low-light, and it has macro capability (which I have yet to play with).
    If you're on a budget and want a quality remote then this is an absolute bargain.
  4. brifobwad
    brifobwad
    Nov 29, 2002
    68
    11
    Rosyth
    I got mine when I bought my Nad T752. The instructions for using it is in the manual for the T752. Unfortunately the manual reads like it has translated from another language.( French Canadian > Chinese > English ) You can find details/ manual at http://www.nadelectronics.com . I already had the AIO Mosaic and find that easier to use.
    Nad don't seem to reply to emails. I emailed a question to them in December and I am still waiting for a reply:mad:
