Nic Rhodes
Does anyone know if it uses the old software or is compatible with it?
Did you mean upgrading the AV32R software,or hardware?....if it's just software,I'd be inclined to leave that,even if the IAG/Audiolab software was compatible,under the assumption of "if it ain't broke"!Nic Rhodes said:trying to work out whether to upgrade the AV32R to more modern spec, but I see no idea on whether this is a dead end or not, despite all the time that has passed. If they had 'tweaked' the software for the AV30 replacement it might helped the decision a little.
A DP will serve you well........ An AV192R with all the RGB board will give you the video switching/balanced outputs etc.Nic Rhodes said:trying to work out whether to upgrade the AV32R to more modern spec, but I see no idea on whether this is a dead end or not, despite all the time that has passed. If they had 'tweaked' the software for the AV30 replacement it might helped the decision a little.
Graham:GrahamMG said:I am still completely unexcited by any HDMI connectivity in an audio device.........
Hi GrahamGrahamMG said:...at long cable lengths it ..... at sensible money mind.....
