The Model kit thread. (for people who like to paint and build Airfix, Bandai etc)
nheather
£15 from the local model shop , can’t complain at that !!!!
and the tracks have locator pegs so I don’t need to melt them together 🤣🤣🤣
Isn’t those that you have to melt - push them through, melt the ends down to rivet the two ends together.
Or are these the newer type that you can glue together.
Cheers,
Nigel
paulyoung666
Cheers,
Nigel
Talking to the shop owner , very nice bloke , he said superglue or melt but I’ve just pushed them together and they stayed fine 👍
nheather
It’s when you come to stretch them to get them over the wheels and sprockets that they might come apart.
However, that depends on how you fit them - paint them first and then fit or fit and then paint.
Where the return track is covered by a fender and skirt it doesn’t matter that much - you can even just glue them to the tops of the wheels.
Tamiya made a bit of a goof with their recent Crusader (upgrade of an old Italeri kit). They made the tracks too short which caused a bit of an outcry for a new release £40 kit. But after the initial fury most settled down accepting that if you position the gap on top of the wheels no one will know it is there.
Cheers,
Nigel
grant666uk
Wow for once I can't keep up with the thread. Magic !! Tonight I hope to drill the wings for rigging at a later point and get a black pre-shade down.
grant666uk
This kit is a ball breaker. Done fir the night.
nheather
Wrong thread I know, but it'll work better in this thread
TIL that the camouflage on RAF aircraft was painted according to fixed patterns. So the brown and green that you see on Battle of Britain Hurricanes for example was the same on each aircraft (or certainly intended to be). There were, in fact, two patterns used for day fighters of both the RAF and the FAA (Fleet Air Arm - Royal Navy) - Pattern A and Pattern B. And even these were the same, Pattern B was simply the mirror image of Pattern A.
I'd always thought it was random.
Cheers,
Nigel
paulyoung666
attention to detail on a large scale :rotfl: , to be honest I would have just thought they would have just thrown paint at them , everyday's a school day !!!!
nheather
I imagine they had big paint masks at the factories. I suspect that as more and more repair work was done at the airfield facilities it would have been less precise but still following the general pattern.
Cheers,
Nigel
grant666uk
My high tech workstation 🤣🤣🤣
I like your little alien looking light, I also have those same tweezers and by flip they are sharp and pointy !!!
grant666uk
Thats some pre-shading done. Not sure if i should lay down a dark colour then mask all the rib lines. I hate masking. So boring.
aVdub
I've probably stuck the tweezers into my digits more than I have used them to pick up or hold small things.
aVdub
that shop is usually a good shout for tools that aren't going to see a hard life , the only problem now is they queue round the block to get in ......
I can imagine.
Happy for the time being tbh to use online and cut down the risk.
grant666uk
Do you find pre-shading works? What colour are the wings going to be? Will be interested to see what effect it creates.
Cheers,
Nigel
Yea it does. The only problem is I am heavy handed and always over spray and hide most of it. You can see it on the wings in this pic....
grant666uk
I noticed that little palette set that looks like make up today , cheaper than I thought at £7.99 ....
About our ads
Yea the soot and oil one is super handy. Oh and they last forever. Worth picking up for sure.
grant666uk
Tonights work done. This time i am building and rigging the landing gear before i attach them. Fingers crossed it makes it less painful than on the Roland.
nheather
View attachment 1325131View attachment 1325132View attachment 1325133
Can see the pre-shading working there very effective. When I have tried that method in past I couldn’t see any difference, probably a combination of too heavy a coat and that I mostly do military vehicles which tend to be dark greens and greys.
Cheers,
Nigel
Similar threads
Podcast: LCD TVs for Movies, Laser Projectors, RIP Ennio Morricone, AV & Movie news, B+W Matt Damon
Trending threads
Latest News
QDC Blue Dragon earphones on sale in UK
  • By Andy Bassett
  • Published
TV licence fee now applies to over 75s from 1st Aug
  • By Andy Bassett
  • Published
New H.266 video codec promises 50 percent data saving
  • By Andy Bassett
  • Published
Toshiba launches UL20 4K HDR TVs from £299
  • By Andy Bassett
  • Published
LG GX soundbar launches in UK
  • By Andy Bassett
  • Published
