the missus is about to kill me
Discussion in 'Plasma TVs' started by ahandpatsy, Mar 13, 2005.
  1. ahandpatsy
    ahandpatsy
    Mar 13, 2005
    46
    i have just got a pw6 from richer sounds with no other input apart from the vga input
    i was told that if i buy a scart / vga converter this would work, which i did
    1. when the dvd is the source the screen is bright pink or blue. i changed scarts, dvd's, settings still the same
    2. when Sky + is the source there is no picture atall. there is a signal but no picture.
    please help as the missus is on the you paid what for this trial
    andy
  2. njr
    njr
    Aug 23, 2002
    113
    16
    Berkshire
    Sounds simple, I hope!
    Go into the picture menu on the PW6 and check whether you have the VGA input set for RGB. It sounds like it is set on component, that is why it is pink/blue on DVD. change as appropriate.
    For sky, check that you have the skybox outputting RGB signals, go into the sky setup menu and into the picture settings, change the picture output to RGB.
    My guess is that this will sort out your problems.
  3. ahandpatsy
    ahandpatsy
    Mar 13, 2005
    46
    not so simple
    on pw6 the settings are component/rgb selected as RGB
    input label selected as RGB
    both are now showing as no signal ?? on the screen (sky and DVD)
    i have a js technologies RGB to plasma converter VGA v.2
    The input says RGB Scart (this is a normal scart yes ?)
    any help ?
    andy
  4. Mep
    Mep
    Dec 25, 2004
    9,578
    Surrey
    +474
    how are sky and dvd connected to each other?.......and just to ensure its not the obvious is the red light on on the js?
  5. ahandpatsy
    ahandpatsy
    Mar 13, 2005
    46
    to try and keep it simple i have the dvd and sky not connected
    so the dvd scart goes into the scart vga converter and the sky does the same when i'm trying to get that to work
    yes the red light is on
    andy
  6. Mep
    Mep
    Dec 25, 2004
    9,578
    Surrey
    +474
    if you click on signal what is your sync setting?
  7. ahandpatsy
    ahandpatsy
    Mar 13, 2005
    46
  8. Mep
    Mep
    Dec 25, 2004
    9,578
    Surrey
    +474
    change to auto or vbs
  9. ahandpatsy
    ahandpatsy
    Mar 13, 2005
    46
    there is only CS or H+V ??
  10. Mep
    Mep
    Dec 25, 2004
    9,578
    Surrey
    +474
    thought it would be same as pw7...have you tried those options?
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    H+V is what you ned for the JS box try that and while RGB scart is a fully wired scart cable you have to tell the source device (DVD player) to output RGB on Scart most default to composite which will give you no picture
  12. ahandpatsy
    ahandpatsy
    Mar 13, 2005
    46
    ok dvd working perfectly now, thanks
    any more ideas on the sky ??
  13. Mep
    Mep
    Dec 25, 2004
    9,578
    Surrey
    +474
    is sky set to rgb in the picture settings and scart control on?
  14. ahandpatsy
    ahandpatsy
    Mar 13, 2005
    46
    thankyou thankyou thankyou
    really, a thousand thankyous it looks fantastic.
  15. Mep
    Mep
    Dec 25, 2004
    9,578
    Surrey
    +474
    brilliant!...really glad its working mate.
