the low level hum is driving me crazy,
Discussion in 'TAG McLaren Audio Owners' Forum' started by harv, Jul 26, 2005.
  1. harv
    harv
    Jul 26, 2005
    254
    london
    +4
    I dunno if its always been there but recently I noticed a low level hum coming from my power amp (100p) and now that I've noticed its all i can hear when there is no music playing. Its wired with a kimber yello power cord and plugged into a isotek solus gII. Has anyone else noticed this; is it normal or should I start saving for a repair bill?
  2. roversd1
    roversd1
    connect the 100P via the original mains lead straight into an ordinary mains plug, does it hum?
  3. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    :smashin:
  4. roversd1
    roversd1
    you know how I feel about 'special' cables, mains filters etc :D
  5. harv
    harv
    Jul 26, 2005
    254
    london
    +4
    I've already tried that, didn't make any difference. Also tried using the isotek and the tag supplied cable and still had a hum. You can only hear it when you're near the amp but once you've noticed...
  6. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Are you saying the actual unit is humming and it isn;t coming fromm the speakers?
    If so then it is almost certianly transformer noise, they (transformers that is) all do it, some make more noise than others...... You can (fingers crossed) get the transformer replaced but it might also make a noise over time...... Such is life....
    I assume you have taken the unit to a mates house and tried it there just to isolate any mains imbalance that may be present in your house? Mains imbalance can also make transformers hum mechanically.....
  7. roversd1
    roversd1
    Look underneath the unit, locate the transformer. If you are lucky and my memory is correct, you may be able to locate a screw that tightens up the transformer (sometimes its a nut inside).
    Failing that, if the hum is not over the speakers, you may have to live with it.
    Try the amp on the normal TMA power lead in a different room. Bear with me as the amp may simply be showing up a minor issue with your house electrics as per Graham.
  8. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Just for my peace of mind, unplug the unit before you tighten it up...... :lesson: Lifting the lid and getting at the nut might be the other way...... Be careful as F@*$ing tight isn't good either...... Did TAG put rubber disks between the Toriod and the metal clamp washer?
  9. roversd1
    roversd1
  10. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    So as long as the 4ft monkey wrench isn't used and a modicum of common sense is used, not much chance of it going wrong then......
    As usual if in any doubt at all get someone that knows what they are doing involved, less likely to end in tears that way.....
  11. liam_b
    liam_b
    Apr 24, 2002
    390
    28
    Wilds of north Leicestershire
    +25
    Start by switching and unplugging the mains, then remove all the connections to the amp, plug back into the mains using a standard kettle mains lead, power up the amp and see if it still hums. If it does then it sounds like either DC on the line or the transformer has become noisey.
    Most mains filters and specialist cables do nothing to remove DC from the line or improve the basic quality of the mains feed, they just cost money and give little real benefit (just like Tony :devil: )
  12. harv
    harv
    Jul 26, 2005
    254
    london
    +4
    Just had a look underneath no visible screw. Not that techy minded to take the cover off, will try at my bro's house to see if it my mains supply. If not I'll have to live with it until I trade it in.
  13. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Hi Harv.
    What RoverSD1 suggested is a 2 minute thing, find someone skilled in such things and give it a go, you have nothing at all to loose. Personally my 100x5R would be irritating for the same reason but I built a big cabinet and bunged it in so don't hear it, mind you when the neighbours are out I wouldn't hear the hum anyway :devil:
  14. Nuno Santos
    Nuno Santos
    Jul 25, 2000
    148
    Portugal
    +3
    LOL :thumbsup:
  15. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    This subject was covered here:
    http://www.avforums.com/forums/showthread.php?t=220447&highlight=DC+mains
    Since this thread a pre-built device called a GF-1 made by TK-Audio in Germany has come to my attention, *hopefully* it should shut up the humming transformer in your amp by removing the DC offset component from the mains. I've never used one personally, but I know a few people who have tried it and it did the trick. If you do a search on Ebay.de you can often pick them up at quite a good price (do a search for TK-Audio GF-1 Netzfilter). It's an inline box of tricks so requires no electronics or engineering know how to install.
  16. harv
    harv
    Jul 26, 2005
    254
    london
    +4
    Thanks (all) for the advice, will have a look over the w/end. On a another note what would be a good value for my amps ? for trade in (spotted a second hand krell 300i). The amps are a 60i and 100p.
    thanks again
