adam-burnley
As I'd stuffed the riser with Rockwool, it might as well double up as broadband bass trap, of sorts. To be really effective it will need holes, lots of them. Obviously that would weaken the structure, so will have to make do with some rear and front facing vents.
First I cut out the board
Then used a bit of weed membrane to prevent Rockwool particles from blowing back in to the room
Fitted a vent grill
Then repeated four more times
A big thanks to @bardel for the idea!
Fitted a vent grill
