The impossible stand????
daverob
I am looking for a stand to accommodate a Pioneer-LX5090UT - dimensions for the stand I need are: width: 1233mm (or slightly more) - Depth: 93mm and height no more than 80mm. Have been trawling through many sites looking for a stand as close to my requirements as possible - but to no avail!! Any ideas as to where I might be able to find this stand????:lease:
Knightshade
You really want a stand that's 9.3cm deep and 8.0cm tall?
Are you using Nano components???
daverob
Hi Knightshade, In a word NO!! But am still looking for a stand with the dimensions I originally posted!!
Member 324728
Hi we can make you a stand any size you like however the 93mm is probably the thickness of the TV and not the base it is attached to.
daverob
Sorry about any confusion. I actually mean't no to the question was I using NANO components!!!! Not to the dimensions. However I have now located a stand for my new Pioneer 5090 - it's part of the Atacama range:)
