The Hasselblad Xpan ratio
Discussion in 'Photography Forums' started by Member 79251, Jan 21, 2008.
  1. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    A friend of mine has just pointed this out to me regarding a different way to crop your images, it might be useful.
    The link to the site: http://www.fototheque.com/xpan/index.html
    and some examples:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. springtide
    springtide
    Oct 7, 2005
    5,877
    +1,481
    Still confused :eek:
    So, for medium format cameras (like the Pentax 645) in normal aspect ratio, what would be the crop factor? Around 0.6 ??
  3. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    Christchurch , New Zealand
    +748
    Crop factor?
    Try this:
    [​IMG]
    The xpan just uses 2 35mm frames for its panoramic look, and IMo produces excelent results. I htink you need the film processed by people who know what there doing with it.
  4. springtide
    springtide
    Oct 7, 2005
    5,877
    +1,481
    So basically....
    35mm has a ratio of 3:2
    Medium format has a ratio of 4:3
    Medium format has a "crop factor" (for comparing lenses) of 0.71 (36/50.7) width and 0.61 (24/39) height.
    So, when comparing a Medium format lens to a 35mm say for a wide angle, a 35mm medium format lens is like a ~23mm FF lens.
    i.e. a 35mm Medium format lens is like a 25mm/21mm lens in FF(35mm) terms.
    Is that about right?
  5. danburbridge
    danburbridge
    There isnt't just one "medium format" however
    You have (on 120 film)
    "size" | aspect ratio | actual size
    6×4.5........1.35:1......56 × 41.5
    6×6...........1:1..........56 × 56
    6×7...........1.25:1......56 × 70
    6×8...........1.37:1......56 × 77
    6×9...........1.50:1......56 × 84
    6×12..........2:1..........56 × 118
    6×17..........3:1..........56 × 168
    6×24..........4:1..........56 × 224
    645, 6x6 and 6x7 are most common sizes
