The good and bad of hard drive recorders
Discussion in 'Blu-ray & DVD Players & Recorders' started by SDHoward, Dec 31, 2004.
  1. SDHoward
    SDHoward
    Nov 1, 2004
    250
    The good
    Today, 8, hour long episodes back to back, and they can be recorder without having to swap tapes/dvd's etc
    The Bad
    When the wife accidentally unplugs it for a few seconds half an hour before its all over you loose the lot.
    why cant they sort of every 10 minutes or so properly save it or something.
    ok I'm off to sulk
  2. JayCee
    JayCee
    Jan 20, 2004
    22,420
    Lanarkshire
    +2,346
    I take it she was using the socket for the Hoover :laugh:
  3. SDHoward
    SDHoward
    Nov 1, 2004
    250
    Yep :)
    It was partly my fault though, as the recorder was a relativly new addition and I'd run out of spaces on the multi gang socket everything else is plugged into...
  4. skes
    skes
    Dec 13, 2004
    117
    Halifax, UK
    Is she still alive LOL
  5. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    Bit of a side issue but really you should have your video/audio equipment on a separate surge protected/rfi supressed socket, it should be forbidden to plug anything else into it, especially things with motors like hoovers.
  6. JethroUK
    JethroUK
    Dec 5, 2004
    1,144
    +34
    even with an 8 hour back2back - i'd be inclined to record in sections maybe hourly - then you'd prolly only lose last episode
  7. Tomo1971
    Tomo1971
    Dec 30, 2004
    193
    Glenrothes, Fife
    +6
    Better than the story in a Hospital where the cleaner unplugged a piece of life saving equipment to use the floor cleaner. Several patients died in this particular bed and they couldnt work out why for weeks and weeks. they thought the bed was haunted or something.
    Steve
