B
Beethovenian
The iPod may be simple to use and all, but it's not as intuitive as it could be, and I don't think the HD5 is any more difficult to use. But granted, there's no better control system than the click wheel so far, just because it makes easier to navigate through long lists.
As for iTunes, I downloaded it to see what all the fuss is about and didn't like it. True, it's smooth, very fast, things you can't say about SonicStage. But it's way too oriented to song people, and not album people. That small genre/artist/album view on top helps, but I think Windows Media Player has a more logical organization in some senses, and SonicStage is nice in allowing you different views, like having larger thumbnails of your album covers and listing all albums. But that's not the problem. The problem is that I can't see iTunes as a PC jukebox simply because it's not gapless. I tried some Lame aps MP3 files of Sibelius 2nd Symphony and iTunes went crazy. Without the crossfade to zero option, it obviously played as the iPod, with a more than noticeable gap. With crossfade to zero, the transition from 3rd to 4th movements became a mess. There was no gap, but for some reason the fourth movement started before the end of the third. To check files, I played the same tracks with Foobar. No gaps, no undesired crossfades, only regular playback. Then I copied the Gloria and Et in terra pax from Bach's Mass in B minor and the third and fourth movements from Beethoven's Fifth Symphony directly using iTunes and AAC. With crossfade to zero, both had slight glitches. The transition was much smoother, but in no way was as in the original CD. It sounded as if some beats were eaten, simply disappearing. And I couldn't see any option to join tracks after you had ripped them. Is it like that? If so, then there's absolutely no difference to SonicStage's problem of only being able to offer gapless for music encoded directly from the CD. Or better, there's the difference that you lose individual track information, plus the ability to jump to any particular track.
