Introducing the NAD M10 - See it at our Future Of Sound 2019 Tour
BluOS MAKES THE M10 SOMETHING SPECIAL
BluOS is the most advanced network streaming and multi-room operating system available. Part of a growing ecosystem of compatible products, BluOS tightly integrates hardware and software for an unbeatable user experience. The only wireless high-resolution multi-room system available today, BluOS supports the new standard for high res streaming, Master Quality Authenticated (MQA). With support for over 15 free and paid subscription services, as well as supporting locally stored music libraries, BluOS makes the M10 incredibly versatile. Adding additional rooms is easy and affordable using Bluesound’s all-in-one speakers, or you can add premium components from NAD, Dali, and others to provide amazing sound throughout your home.
UNDERSTATED ELEGANCE
With Industrial Design by award winning design firm DF-ID, the M10 takes a minimalist theme to new levels of elegance. The slender proportions are enhanced by authentic materials including solid brushed aluminum and smooth glass. Completely operable by Wi-Fi connection to the BluOS App, one need never touch the M10 in order to listen to your favourite songs. As you approach the M10, the high-resolution touch screen beckons as the graphic changes from ‘now playing’ to ‘control panel’ allowing many operations directly from the front panel without opening an app. It also shows what’s currently playing and what is coming up next in the play queue.
UNMATCHED PERFORMANCE
The M10 uses NAD’s most sophisticated Masters Series technology to create a sonic performance that is second to none. HybridDigital amplification featuring the remarkable Hypex nCore amplification stage offers state-of-the-art performance along with the ability to drive any loudspeaker. Highly efficient and remarkably powerful, the M10 can render even the subtlest of musical details with vivid realism. Effortless dynamics and a complete absence of electronic noise are hallmarks of this advanced technology.
EASY SMART HOME INTEGRATION
We have spent considerable effort to make the M10 fully compatible with today’s leading smart home systems from companies such as Apple, Crestron, Control4, Lutron, and many others. This means that along with your lighting, shades, HVAC, and security, you can seamlessly control your BluOS multi-room music system from a common interface. All of our integrations are certified for reliable operation. We also have custom BluOS apps for iOS and Android mobile devices and tablets, as well as desktop control from Windows and Apple OS.
MUSIC MEANT TO BE HEARD, NOT SEEN
The NAD M10 represents a new kind of high-end audio system that is luxurious and smart, but very discreet. It can perform the same functions that once required a rack full of components and in many ways is superior. The elegant form factor takes up very little space and can even be hidden away, but the beautiful design and colourful display will encourage you to place the M10 front and center.
Features
•BluOS Streaming Amplifier
•HybridDigital nCore Amplifier
•Continuous Power: 100W into 8/4 Ohms
•Dynamic Power: 160W into 8 Ohms
•300W into 4 Ohms
•32-BIT/384kHz ESS Sabre DAC
•1GHz ARM® CORTEX A9 Processor
•Dirac Live FULL Room Correction*
•Color TFT display with Proximity Sensor
•Supports Amazon Alexa Voice Control Skills
•AirPlay 2 Integration*
•Supports Siri Voice Assistant via AirPlay 2
•Two-way Qualcomm aptX HD Bluetooth
•BluOS multi-room compatible
•Gigabit Ethernet
•HDMI eARC, USB Type A Input
•Stereo Line Inputs, Coax/Optical Inputs
•Preamp Output, Subwoofer Output
•IR Input, 12V Trigger Out
•Apps for iOS, Android, Mac OS, Windows,
•Crestron, Control4, RTI, URC, Elan, Lutron,
iPort
•Wide variety of premium music services
supported in App, including Amazon, Spotify,
Tidal, TuneIn, Napster, Deezer, Qobuz and
many others
