The Following A Connection To The Server Could Not Be Established
Discussion in 'Playstation Forums' started by nico_4, Apr 25, 2007.
  1. nico_4
    nico_4
    Dec 10, 2005
    57
    When I Go To Sign Up For Playstation Network I Get The Following Message. A Connection To The Server Could Not Be Established.
    When I Go To Internet Broswer I Get Page Cannot Be Displayed.
    When I Go To The Playstation Store I Get The Following A Connection To The Server Could Not Be Established.
    I Cannot Remember Where And When But I Sometimes Get This Message Too (80710723)
    Im Connecting Wirelessly ( Its The Sky Router ) And That Is Tested All Ok.
    Its Seems Like I Cannot Connect To The Playstations Server But Why.....
  2. nico_4
    nico_4
    Dec 10, 2005
    57
    and it has been upgraded to the new patch....so that hasnt fixed it either
  3. small358786
    small358786
    Mar 17, 2007
    1,195
    48
    +83
    I know it doesn't really help but my mate has the same problem,he has his hard wired yet 50%+ of the time he cant connect either.
  4. nico_4
    nico_4
    Dec 10, 2005
    57
    that does help in a way that i know its not me.
  5. SteveG
    SteveG
    Jan 14, 2003
    1,041
    London, UK
    +92
    I've got Sky Broadband too. I don't have any problems connecting to the PSN, but do occasionally get logged out of the network with the 'A network error has occurred' message. I've made a few changes so hopefully this may be resolved now.
    Some things to check:
    - Assign a static address to the PS3 (not DHCP or one already in use!).
    - Make sure this address is excluded from the routers DHCP scope
    - Manually put in the IP address details and make sure the first DNS server is the IP address of your router. For the alternate DNS address put in Sky's DNS server 87.86.189.16
    - Put your PS3 in the routers DMZ (add it as the default DMZ server). I guess this could potentially make the PS3 less secure than behind the firewall, but if it stops connection problems (by blocking ports) then thats a good enough reason for me to do it. I tried adding all the PS3 ports as a service but still got random disconnects.
    - Enable UPnP on the router if it's not already.
    - Test the connection and make sure it reports NAT Type as 2.
    Login to the Sky router (//192.168.0.1) with username admin, password sky
