the final touch.
Discussion in 'Home Cinema Buying & Building' started by krusty, Apr 16, 2005.
  1. krusty
    krusty
    im at a stage now where i have all the kit i need, thing is my viewing room i think is giving me accoustic problems. i have quite a large front room and my walls are painted and the floor is carpeted. if i paper the walls will this improve any room boom, or harshness. my yammy a2 has tons of complcated settings that are lost on me.
  2. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    HAA calibration will identify whether the room is causing problems and identify the fix. Papering the walls will have no substantial effect.
  3. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    ^^what he said, dont forget to check out the powerbuys im offering if you do need anything, we are VERY flexible!
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,180
    UK.
    +2,720
    Set up your speakers and try them. Then decide if the room has any unwanted echo (slap echo - clap your hands and see if it echoes). If it does, then the walls may need treating. There are a few threads here which mention various ways odf tackleing the problem so try the search.
    Gary.
