I appreciate that this issue has been discussed before but nobody has quite defined the best solution, soooooo....
Here's the deal:
I have a single storey apartment with marble floors and the living room has no way of running wires across the room without people tripping over them. No carpet either obviously. I have my PC, PS3 and 46" Sony Bravia 3 LCD TV across the room from the couch and Logitech Z5500 surround sound speaker set 5.1 for audio which I know is not necessarily HiFi but actually gives excellent sound for the price. So FL C and FR are no problem but I need my rears across the room beside the couch without wires! The fact that the floor and ceiling offer no options muddies the issue Doh! I can't see that clarity is going to be a major factor as I just need that extra 'sound fill' from the rears.
My thoughts on solutions include:
1 Chop the cables for RL and RR and insert some form of in-line wireless sender to a receiver across the room with a reasonable audio amp and plug the rears into this.
2 Use a powerline adaptor to get the audio across the room. Pop the audio out of the powerline receiver and feed to the rears.
3 Anything you Experts can come up with instead!
Try as I might I have scoured the net and come up empty on Options 1 and 2 so if you can enlighten me ..... Please do
If there isn't anything on the market I might have a go at building something to fit. Would it be a big seller?
Many thanks in advance.
Clay
Here's the deal:
Clay
