Quantcast
The Final Piece of My Jigsaw
Finally i am near completion regarding my setup. Its took a while and a lot of searching but i have managed to get them all at an absolute steal of a price.
Current setup consists of the below
2 x Monitor Audio Radius 270HD (Fronts)
2 x Monitor Audio Radius 90HD (Rears)
1 x Monitor Audio Radius 225HD (Centre)
1 x Yamaha RX-V767 Amplifier
All i need now is a Subwoofer to compliment all of these, so any suggestions as to what? I've been pointed towards the BK Range with the Gemini being the lowest priced one.
So far, the setup has cost me £1030 in comparison to approx retail prices of £1650
mjbtin
Get the biggest BK you can afford:) Room size will have alot to do with which BK will suit best.
Regards Martin
Well, i cant afford any as of yet, with me i decide on something then save for it ;-) Ill get it in the end !!! Room size i imagine when i buy my own place will be your average size living room.
mjbtin
If you get a sub that is too big you can turn it down if its too small it will always be too small.
I was in a similar position to you and was trying to convince myself that the Gemini would be big enough but eventually got the xls200 that is doing a fine job.
Every now and then I think to myself that I should have got the 400 or monolith:laugh:
Whichever you choose they are all top performers for the pricetag.
Regards Martin
