The Evil that is Edge Enhancement
Discussion in 'Movie Forum' started by Jenz, May 12, 2001.
  1. Jenz
    Jenz
  2. Matty N
    Matty N
    Now, you see, there you go again!! I spend all this money on getting a filmic quality presentation at home and then somebody points out all the flaws I have spent time managing to forget.
    Now I've got to get out the Teddy again, where are you Mr Burplepus?
    What's that mother? Oh, yes, coming mother.....
  3. Paul D
    Paul D
    Dec 27, 2000
    2,794
    Manchester
    +557
    Funny you sould mention "EE".
    I have been tweaking the settings on my Vw10ht using Video Essentials etc. I found the sharpness setting to be perfect. Ie i left it set in the middle(50).
    I then tried several Dvds to test for colour/brightness/contrast etc.
    When i started watching the "Wild-Wild-West", i started to notice EE.
    Were Will Smith gets off his horse and walks up the white houses path his black pants show big white halo-ing (ringing).
    I thought it may have been my projector etc.
    I rechecked with V E and again perfect.
    But your link has explained all!.
    I had assumed any EE was added by the dislay device.
    Excellent link, cheers mate :)
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,606
    Somewhere in South Yorkshire
    +6,146
    Fascinating article. Thanks for the link.
    Now it is time for all Magazine Reviewers to start giving "points" for the film transfer, based on viewing on a very large, reference quality, front projection system, rather than the 24" TV many seem to use.
  5. bh
    bh
    Jul 14, 2000
    397
    Lost (no GPS here)!
    Very interesting. In the same way that Jenz' recent article comparing R1 and R2 (using The Fifth Element) has dispelled some notions, this article would suggest that anamorphic does not necessarily lead to a more 'watcheable' picture.
  6. Mr.D
    Mr.D
    Jul 14, 2000
    11,197
    +1,241
    Used to have a lot of problems with EE on video land effects work. Now ensure I forbid the telecine operator to apply any filtering whatsoever.
    Not nice when you pull a key and get a big white/black edge round everything then the client comes back and assumes its your problem. tsk!
  7. LV426
    LV426
    Jul 14, 2000
    13,606
    +6,146
    bh said, "....this article would suggest that anamorphic does not necessarily lead to a more 'watcheable' picture. "
    Like everything, each factor has to be considered "all other things being equal".
    So, Anamorphic DOES mean a more detailed picture "all other things being equal".
    PAL should give better resolution than NTSC "all other things being equal".
    If all other things are not equal, comparisons based on assumptions like these don't work - "it's PAL so it must be better than NTSC" isn't true because other things aren't equal.
    This is why the theoretically better PAL version of The Abyss is pants compared to the theoretically worse NTSC one.
  8. Gary Palmer
    Gary Palmer
    Jul 17, 2000
    333
    16
    Jenz,
    I'm gonna kill you.
    I can't watch a movie now without looking for little halo EE effects..........
    (very useful and informative link. Thanks)
    Gary
  9. Arthur.S
    Arthur.S
    Very interesting Neil,
    This was one of the few things that vexed me when I moved up to a projector. When I changed from S-V to RGB though, ringing vitually disapeared. Any theories as to why anyone?
  10. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    Edge enhancement isn't just on DVD's. Over here they add it to television programming on some channels.
    Watching hockey or golf they whack it up so you can see the puck or ball more easily when it's flying around the screen. Nightmare!
    Gordon
    Still on hols in Canada
  11. Mr.D
    Mr.D
    Jul 14, 2000
    11,197
    +1,241
    Could be an SVM (scan velocity modulation) circuit in the composite paths in the projector. RGB should bypass this.(as long as its not screwed with in an additional sampling stage)
