The "dreaded C1300" error message.
Discussion in 'Blu-ray & DVD Players & Recorders' started by paulr, Dec 15, 2003.
  1. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    Only last year i bought a top of the range Sony 900v dvdplayer thinking it would play everything.More often than not i now get the "C1300 disc is dirty" error message when playing dvd-r's.
    Its not every disc,approx 50%.
    Is there anything you can do,why does it happen?
    (Bulkpaq or Datasafe media and Nero)
  2. Duster
    Duster
    Dec 4, 2002
    421
    UK
    I was getting alot of the same error message, on my Sony RDR-GX7 DVD recorder, when recording.
    I sent it back to Sony, and they did a software update. It seems better now, but I still get the same error from time to time...:(
    Maybe you need a software update too???
  3. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    Duster..have you any contact details for Sony please.It'd be much appreciated..
  4. Duster
    Duster
    Dec 4, 2002
    421
    UK
    In my case, I just sent it back to the place i purchased it from.
    As it was only 3 mouths old.
    Here is an email address for Sony service-
    [email protected]
    Tell them the problem, and ask for advice.
    They answer in 2-3 days.
    Good luck, I hope you get it fixed:smashin:
  5. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    Thanks.
  6. mjn
    mjn
    May 24, 2001
    22,436
    Herts, England
    +10,472
    its a sign the laser is failing, or can't focus on the dvd correctly.
  7. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    New Zealand was Nottingham
    +86
    I had the same problem earlier this year on my 900. Turned out the laser needed to be replaced. Done free by Seven oaks.
  8. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    It only happens on copies though,NEVER on legit dvd's.
  9. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Well Ive never had a copy. Also my player refused to read anything.
  10. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    Is there any update on this,the C1300 error.I still have the DVD player and since it cost me £430 i'd like it fixed.
  11. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Jeez this thread is over 2 1/2 years old :eek:
    Like I posted back in 2003, its a laser problem. It needs to be replaced.
    To be honest you could (will) get a new player with more features ect. for what it will cost to have the repair done :)
  12. squelly
    squelly
    My RDR-GX7 had been rejecting all discs burned and purchased. Giving a "disc is dirty" or c1300 message with every disc. Seeing how this seems to indicate a bad laser, I tried as a last resort to blow the dust off the laser lens. I got a can of compressed air and stuck the thin tube down in the open tray and blew a mess of dust out. I also opened the case and blew the dust of the circuit boards.
    All my discs started working again. :thumbsup:
  13. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    Okay, since i posted this i've stopped using copies. Joined lovefilm.com. Problem solved.
