The Cycling Thread Part 2
Status
Not open for further replies.
IronGiant
Looks gorgeous Dave. Is there any way to buff/restore the saddle rather than buying a new one?
Sebastalona
What a great job Dave, hard to believe it's the same bike from your original shots.
For what it's worth, I think the slightly worn saddle helps retain it's charm of a restored classic if that makes any sense!!??
IronGiant
I think I missed the originals, can some kind soul point them out? Thanks.
Good point about the saddle :smashin:
Miss Mandy
Looks great Dave, nice work.
Sebastalona
figoagogo
Wow, some effort, out of interest, what did you pay for all this i.e. bike + getting into the condition it is, and is it now worth anything? Not that this is a valid reason for doing it, I am just intrigued.
Not a "retro bike" fan myself, but I can just imagine people paying well for this sort of stuff.
Well done!
Dave
Well done!
The bike was a freebie from a mate's Mother. Her Brother died a number of years ago and my mate's Brother had tried to restore it with zero success.
Imagine my surprised when she offered it to me to try and do up, I thought it was a right POS when I first saw it but a little research revealed it to be an Italian classic.:eek:
I've bought in no particular order, 2 tins of paint, 1 tin of lacquer, 1 tin of undercoat, some wet and dry paper, 2 gear cables, 2 brake cables, handlebar tape, a new saddle, 2 new tyres, 1 inner tube, 2 rubber o rings for the brake adjusters, 2 crank dust covers and a set of stickers.
Total comes to about £120ish for that lot and approximately 40 to 50 hours working on it.
As for it's value now it's very difficult to say, in minty mint condition and going by ebay you're probably looking in the region of around £800 but that varies massively and bikes that have had resprays are not very sought after by classic collectors for some reason.
I'd guesstimate that my bike would probably fetch about 4 to 5 hundred quid. Despite being rather old Gios bikes are also very very good and with campagnolo components throughout and the columbus tubing it could give many modern bikes more than a run for their money.
That's the theory anyway, I haven't even rode it yet cos of the rubbish weather.
Here's what it looked like before if anyone missed it, very sorry for itself.
figoagogo
Excellent, well like a said, good job.
I will stick with my 2 x 10 :)
I am getting more confident working on bikes now, but stop short of messing with the BB. Just fitted a new 105 groupset to my bike and think I did a good job, even the bar tape looks good, but its the old stuff for practice, need to replace that.
I hope to one day find a kids road bike frame to do up for my son, he has a MTB, but I thought it would be nice to put a custom built road bike together from various parts. I will keep any eye out for something special.
3T3L1
just found this thread - well impressive job doing that bike up :)
one question - i'm not particularly confident with tools etc but have always done the basics on my road bike (second hand Carrera originally from Halfords) but am getting a bit more confident and want to know whether things like changing the chain is the kind of thing I can do at home or is it best to be sure and get it done at the bike shop?
Have read loads of guides on the net and You Tube but still don't have the confidence to try - my main worry is that I do 25 miles to work and back most days and a breakdown wouldn't be a good idea!
Dave
I would say that if you are capable of changing a tyre you can change a chain. If you have the tool it takes about 2 minutes.
If you get stuck just ask.
3T3L1
cheers for that - just need to wait for the weather to get a bit better then buy a chain (got a multitool recently which has a chain tool on it) from the shop.
need to give the whole bike a bit of a service - need new brake pads as well so it's the sort of thing to not do in the cold!
Dave
Out of interest what's wrong with your current chain?
3T3L1
It's done about 1000 miles and occasionally skips/fails to sit properly on the front cog.
The last one I left til it got close to going as I didn't realise it needed changing occasionally so was lucky to not kill my gears (according to the net).
Now I've got a tool I'd like to do what is apparently recommended and change the chain to clean it occasionally and switch them over.
Is that a myth then? Should I just keep mine until it gets really knackered and just get a new one?
Dave
Unfortunately there's a tool to check it which means buying one. On top of that if your chain is skipping it probably means you need a new cassette too as they tend to mesh with the chain, using an old cassette and a new chain will destroy both very quickly. The chain ring is normally ok for a lot longer though.
Are you sure it's not the front mech that needs adjusting rather than the chain?
3T3L1
Don't know - I'm going to display my ignorance and ask what that is! :blush:
The last time I had the chain changed ~ 6 months ago the bloke said the cogs were OK as I'd done it just in time.
It's only an occasional skip which I'm sure is due to a tight link as it gets better when I oil the chain. Though that's probably wrong!
Dave
The front mech is the metal bit above the big cog that changes the gear when you move the shifter. If it's poorly adjiusted it can mean your chain will skip from time to time. Does it make a noise like a ticking sort of sound as you turn the pedals?
3T3L1
Occasionally when the chain is on the biggest cog at the back you hear a clicking noise when you pedal - it has been a bit more a pain to shift between the small and big front cogs recently which I'd put down to mud and crap getting in there with the rubbish weather, and I never tend to use the smaller of the two front cogs.
Would it be a matter of undoing the cable holder, giving it a clean and then doing it up? Don't want to damage it...
Dave
It sounds far more like you need to adjust the front or rear mech than buy a new chain and best of all, it'll cost you bugger all.
There are plenty of video guides on youtube etc, just have a look and try it. It's hard at first but once you've watched a few guides and got a feel for it you'll have no problem at all.
3T3L1
Cool - thanks for your help.
Will look it up and see how difficult it seems.
Am still tempted to bottle it and get it in the bike shop to get serviced this time and then do the undoing and adjusting bits in the summer when it's more fun to be outside with dirty hands!
Dave
Don't do anything outside, all of the above can be achieved in the living room with an old towel on the floor to save any spillages.
I've just rebuilt a bike from scratch twice in the kitchen, the better half wasn't happy but there's no need to do it outside.
As for the bike shop have a go yourself first, if you don't succeed you can always go to a bike shop anyway. There's very little indeed you can do to a bike that will make it unrepairable at a bike shop.
Status
Podcast: The Best TVs and Projectors of 2020, plus AV, TV Show & Movie News & Reviews
Latest News
AVForums Podcast: 2nd December 2020
  • By Phil Hinton
  • Published
Klipsch announces four Cinema soundbars for UK
  • By Andy Bassett
  • Published
Elipson adds Connect 250 streaming amp to Connected range
  • By Andy Bassett
  • Published
Cyrus Audio announces XR series Hi-Fi products
  • By Andy Bassett
  • Published
Sonus faber announces Maxima Amator speaker
  • By Andy Bassett
  • Published
