Good Luck! Hope you win thousands
I love that show and although it does seem easy sitting on the sofa I think some of the challenges are very tricky...it's usually the short amount of time you have where you basically have to be completely calm as well as lightening fast.
Btw - did you see last weeks with that kid who got to £100,000 - he made it look easy.
i think i would be ok with the the games that are either memory based or reaction based, or the ones where you walk a line blind folded, but my downfall would be games where you need to throw and object over a wall and into a basket, or when you need a steady hand to thread a long pole through 5 spaced out holes etc.
