Quantcast
The Cave / Garden Studio
CGMarshall
Hi Guys
This is my attempt at a practical home cinema garden studio.
Here is the spec followed by the build
The Cave
> Insulated 13m² building with bifold doors and decking​
> Black all weather paint​
> Cat 6 Ethernet cable, 300mbps DL speed, power running from the house​
> Full security system​
> Siri voice controlled Sockets Switches and Spotlights​
> Storage unit with screen​
> Tools Storage​
> Sofa / double bed (so can be used for guests)​
> Mini fridge​
> Jarvis standing desk​
> Faust linoleum desk table top 208cm x75cm​
> Anglepoise lamp​
> Blackout blind​
> Motorized bifold door blackout blind​
> Duronic Projector Mount PB03XB​
> BenQ W2700 4K Projector​
> Elite Screens SB92WH2 92-Inch​
> Denon AVR-X3600H AV Receiver (5.2.4 dolby atmos)​
> 6x KEF T301 speakers​
> 1x KEF T301c speaker​
> 2x KEF Ci130QR in ceiling speaker​
> 2x KEF T2 subwoofer​
> FosPower Banana Plugs​
> KabelDirekt speaker cable​
> AmazonBasics Subwoofer Cable​
> FeizLink 4K HDMI Cable​
> Monoprice Certified Premium High Speed HDMI cable​
> Optical mini toslink to toslink cable​
> Mac Pro​
> Ducky year of the dragon keyboard (Brown Cherry MX)​
> LG 21:9 UltraWide 34UM95​
> AmazonBasics Single Monitor Display Mounting Arm​
> 2x Herman Miller Aeron Chair​
> Alien by João Ruas #/15​
> Predator by Grzegorz Domaradzki 6/10​
This is the back garden before:
This is probably overkill but I made a 3D model, so i could take my iPad 1:1 scale and walk around in augmented reality to see if it would work in the space.
Here is a video example of the AR:
Remove the old shed, concrete, washing pole and make a flat foundation. Grow some more grass.
CGMarshall
Still need to run the cables in the walls, and do a little touch up paint, but its getting close to being finished.
–– ADVERTISEMENT ––​
inzaman
Looks great, did you build the garden studio yourself from scratch, or was it in kit form and then assembled?
stu74
that looks really good -we recently got a garden room built professionally and for the foreseeable future it will be used as a garden room, there may come a time when it could be used as a cinema room. what steps did you take, if any, to reduce sound/noise outside the build?
There is a lot of timber - have you considered any sound treatments ?
CGMarshall
The cabin is all insulated, and double glazed. when standing out side you can hardly hear anything, even when turned up really loud.
oakland
Looks great and love the video!
Question, did the company run the power supply and Cat6? And what are the intenal dimensions?
CGMarshall
Had my electrician run outdoor sealed Cat6 cable from my router straight to the garden studio, and hooked up the power with a fuse box in the studio.
Similar threads
