The causes of magnetic staining on the screen
Discussion in 'General TV Discussions Forum' started by Cujo101, Apr 22, 2007.
  1. Cujo101
    Cujo101
    May 18, 2006
    553
    London
    +34
    Hello, I'm getting magnetic staining on my tv and I'm trying to figure out where it's coming from. I've got my JVC tv on a wooden tv bench, Dynaudio home cinema speakers 3ft away on target stands, centre speaker on top of the tv and a 5 tier metal Target hifi stand with a metal cased Limit dvd player, Sony AV amp, Yamaha amp, Pace freeview box, Homechoice STB and Xbox 360. I moved the speakers away but the problem remains.
    Any help would greatly appreciated.
  2. bobcats
    bobcats
    Jun 18, 2006
    81
    +4
    1) speaker on top of tv unless incredibly well shielded..
    2) even after you move the speaker you will have to de-gauss..
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    Have you degaussed the TV ?
    Unplug the TV completely from the mains, leave it for an hour to totally cool down; then plug back into the mains and switch the TV on.
    You should her a "thunk" as the degauuser kicks in.
    (Bit of a pain this- my CRT monitor has a degauss switch that you can operate anytime just by pressing it).
    Chris Muriel, Manchester
  4. Medusa
    Medusa
    Mar 29, 2007
    103
    +3
    Possible dry joint in PTC circuit or the positor needs replacing.
    The TV should Auto Degauss when you switch ON don’t leave it in S/BY.
    Sorry! :D
    Could also be the Earth’s Magnetic Field messing about with your TV.:devil:
  5. Mofoman
    Mofoman
    Feb 6, 2007
    167
    28
    +37
    Right, this has happened to me very often, it's sometime's that the tv is directly above the power cables beneath the floor, and if the TV is particularly low, or touchy to magnetic forces, this will cause the screen to get colour stains on the screen.
    So to cure the problem, you can move the tv higher or to a different location in the room. Also if you have power cables in the wall sometimes they can cause it if they are poorly shielded.I've seen it so many times, and it happens in my living room.
  6. JayCee
    JayCee
    Jan 20, 2004
    23,758
    Lanarkshire
    +2,570
    That's a new one :rolleyes:
  7. Mofoman
    Mofoman
    Feb 6, 2007
    167
    28
    +37
    Well, it does happen, I have a main power terminal in my living room, and the power cables running to it in the wall, cause hellish interference with the tv's I have tried to place anywhere in the vicinity.
  8. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,595
    +920
    An area I worked in with a very large metal structural beam caused all sorts of purity issues with standard CRT monitors. The minute we could move to LCDs in this area we did!
  9. zircon3035
    zircon3035
    Feb 23, 2005
    514
    46
    Uncertain
    +156
    Some other possibilities: I've seen magnetic interference caused by electricity meters on the other side of the wall behind the TV. I remember looking at a whole batch of sets with the problem in a warehouse in France, and it turned out to be the metal security door that was somehow magnetized, so check any metal item nearby.
    Also, make sure that you don't move or rotate the set after it has been turned on.
    HTH
    Ian
  10. Cujo101
    Cujo101
    May 18, 2006
    553
    London
    +34
    After a lot of experimenting, I've come to the conclusion that my JVC 32HV-P37 is very sensitive. I switched off the tv at the mains and removed the centre speaker and right front speaker. I've had a Toshiba 32WD98B and a Sony 32FX20U with the same setup and I've never had a problem. I 'm going to have to put up a shelf for the centre, and move my two front speakers.
    Thanks for all the suggestions.
  11. Medusa
    Medusa
    Mar 29, 2007
    103
    +3
    Well Done :thumbsup:
    Onething thats still puzzling me is when did this problem occur?:devil:
    As soon as you put that centre speaker and the two front speakers next to the TV?
    OR after HOURS,DAYS,or MONTHS ? :rolleyes:
  12. Cujo101
    Cujo101
    May 18, 2006
    553
    London
    +34
    The problem has been over the course of days. I think that mains outlets and extension leads may have something to do with it. I decided to move away all the speakers but the problem seems to return slowly over time. The bench that the tv is pretty low down so that may be affecting it.
  13. IndianaBlues
    IndianaBlues
    Jul 28, 2005
    2,060
    +364
    I had a similar problem a few years ago...turned out to be the radiator about 0.75 metres from the set...
  14. hamster
    hamster
    Oct 25, 2005
    472
    28
    +29
    I'd really doubt it's the mains stuff as it's all AC. You need DC for magnetisation. Degauss wands use ac!
