The Builders are in here we go
Discussion in 'Home Cinema Building DIY' started by Maximus1633, Nov 6, 2004.
  1. Maximus1633
    Maximus1633
    Oct 23, 2004
    43
    Manchester
    Hi all here is my home cinema the builder are doing the major work and mains wiring. Im doing all the AV wiring heres some plans and pictures of the start i will update it as more work is done. :)
    hope you enjoy it thanks Maximus1633
  2. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
    Looks good, why not build in an option to easily extend to 7.1 though while you are at this point?
  3. Maximus1633
    Maximus1633
    Oct 23, 2004
    43
    Manchester
    Hi sounds good where would they go?
  4. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
    I would think middle of the room each side, but it's not something I've really looked into, just an idea for the future as 7.1 is becoming more popular.
  5. Maximus1633
    Maximus1633
    Oct 23, 2004
    43
    Manchester
    ok must look into this before all the floor goes in thanks
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    see http://www.dolby.com/consumer/home_entertainment/roomlayout.html for speaker placement advice some people have put them in ceiling for small rooms but ideally stick with Dolby layout as far as possible also suggest you run some cat5 about the place.... never know when you might want to run a PC on plasma or similar. Also get builder to run 3 core to lights and this way you can upgrade from varilight to a grafic eye or similar...pull wiring spec for lutron unit as its worth doing it while you can.....ALso put some string in the pipe to draw extracables through........loads of other tips see moviemikes home cinema progress thread.
  7. Maximus1633
    Maximus1633
    Oct 23, 2004
    43
    Manchester
    Well the biulders are almost done :) Electrician is done :) Plaster is here today to finnish of. AV wiring is all in place i took on the advice for 7.1 and now have 4 speakers at the rear of the room. All the wiring goes through 50mm tube under the floor and was very easy to chase them all through. Next job is painting then the flooring. Here are some more pics. I also put in six mains 50w GU10 halgen in the ceiling working of a varlight dimmer.Now starting to look like a room again. Can't wait till is all finnished hopfully for Xmas.
  8. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    Looking good, keep the pictures coming.
  9. Maximus1633
    Maximus1633
    Oct 23, 2004
    43
    Manchester
    Thanks hunts1uk here's some more picture's. I am making my own AV Unit/dvd storage. The bottom part of the unit is drawers. Top one for remotes, manuals and the odd Home cinema magazine. The other 2 drawers are for dvd storage. The top part of the unit will have 6 slide out shelves for AV equipment 1st shelf is done and one door fitted. The unit will go right up to the ceiling. Run out off flat pack stuff off to B&Q for some more in the morning.
  10. geeWcee
    geeWcee
    Oct 27, 2003
    1,420
    West Yorkshire
    +26
    I love these work in progress threads.
    Looking good so far maximus! Will make a nice xmas present for you if you manage to get it finished for the big day ;-)
  11. Maximus1633
    Maximus1633
    Oct 23, 2004
    43
    Manchester
    Hi there every one hope you all had a good xmas and new year. I just about got my house finnished downstairs xmas eve. floor laid, painting done, lighting done & plasma mounted on the chinney and all the wiring complete enough to watch our first film :thumbsup: The sound and picture is awesome few teathing probs but nothing some tweaking won't sort out here are some picture. Hope you like them im well chuffed. :clap:
  12. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    Looks amazing,well done m8.
  13. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,348
    Livingston, Scotland
    +227
  14. Raze
    Raze
    Dec 21, 2003
    875
    UK
    +13
    wow super cool!
    Can you give us a breakdown of costs just for an idea?
    Are you pleased with it?
    Would you change anything if u re-did it?
  15. Maximus1633
    Maximus1633
    Oct 23, 2004
    43
    Manchester
    Hi Raze the biggest cost for me was the building work its self £6000 but i had other work done apart from this room. The plasma cost £2400 12month old but im realy pleased with it upto now. All the cabling under the floor cost
    alot i havent looked at all those bills yet :) But the biggest change i would make if doing it all again would be to put bigger piping in under the floor as the 50mm tube soon filled up and now i cannot fit any more downthere :(
    The rest off my AV stuff i already had so no cost there. I still have got 4 more speakers to fit but the wiring is all in for them plus a nice sub to get.Got to save some more pennys for them :D Also i fitted varlight dimmers realy good value for money but should have run cat5 for futher upgrade. Other than that im realy pleased with my setup now. Another big plus point was my AV cupboard i built. All the bottom three drawers lift out and then i can slide all the AV shelfs out alowing me to stand up at the back to do all the wiring which was a very big help made is so much better. I must also add a big thanks to everyone on the forum for such good ideas. All helped to bring it together. :clap:
  16. samjpullen
    samjpullen
    Nov 24, 2004
    3,882
    Keighley, West Yorks
    +142
    Major props for that work :)
    i love it, i just wish i could get a nice setup like that.
    i hate being 19, looks like i need to get myself a well paid job ;)
