Trollslayer
Outstanding Member
Do you think he has realised there are a lot of knowledgeable people on AVF?
It is not an undeniable fact,it is an opinion. .. though why someone would want the massive phase transitions that an 8th order filter , whether implemented in passive components or in active circuits using feedback, deserves explanation.
There is an element of the Emperor' New clothes at this highly esoteric end of the market.
Please provide examples to support your statement....I've read too many times his statements on how superior his system was and won bake offs but then other participants of the same bake off did not agree. His credibility and integrity ( or knowledge) aren't first rate.
Transistors are discrete devices so NO.What, so in your opinion, 4th and 8th order op amp based active crossovers don't add a lot of transistors to the signal path?
Of course there are more transistors inside ics, than in even a discrete transistor implementation of an amplifier . There are plenty of good technical reasons .. for instance, transistors being used as loads instead of resistors, thus increasing linearity. The close thermal and doping matching of an ic increases accuracy.What, so in your opinion, 4th and 8th order op amp based active crossovers don't add a lot of transistors to the signal path?
Your opinion on this being based on which actual real life active crossovers?
