The Best Way To Set This lot up?
Discussion in 'Cables & Switches' started by gappyman, Jan 7, 2005.
  1. gappyman
    gappyman
    hi there i have a
    techwood 4210 (scart 1 rgb,scart 2 rgb , scart 3 ,scart 4) connections
    pace sky digibox (vcr scart , tv scart) connections
    panasonic dmr e-50 dvd recorder (av1 , acv2 scart connections)
    cheapo crown dvd player scart connection
    i have no aerial as i just use the sky for input
    wots the best way of hooking all this lot up any advice greatly appreciated thank you
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    Scart from Sky Box to DVD Recorder
    Scart from DVD Recorder to scart 1 on plasma
    Scart from DVD Player to scart 2 on plasma
  3. gappyman
    gappyman
    thx ian but which scart connections do i use on the boxes (digibox & dvd recorder av1 or 2) and tv scrt vcr scrt
    thx
  4. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    The first connection will be from the TV scart on the Digibox to the DVD Recorder but I don't know which scart socket on the DVD Recorder you would connect to - I would suggest having a look at the manual as they always contain a connection diagram.
  5. gappyman
    gappyman
    thanks i ll give it a go
