The best way to remove macrovision with DVD HDD Recorder?
Discussion in 'Blu-ray & DVD Players & Recorders' started by TailsNZ, Jul 19, 2004.
  1. TailsNZ
    TailsNZ
    There seems to be several different devices out there to remove macrovision, for use with a HDD DVD Recorder. Aside from Scart only devices though, what do people think are the best type?
    Obviously picture quality is an issue, so it's probably quite risky just to pick one and try it.
  2. apreading
    apreading
    Jun 28, 2004
    283
    +15
    What other devices are there? I dont think any of the mod chips or firmware upgrades for HDD/DVD machines disable macrovision do they?
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    I found the [removed by lynx] gave an unwanted ghosting on the picture which was impossible to remove.So I would now stick wit KTVision whose leads offer the same quality with no ghosting.
    Apart from these leads,there are no other sensible economical ways of removing Macro.If you want to do dvd-dvd copies,the ideal way is to make sure the player you get has Macro disabled,but this is getting more difficult to find
  4. TailsNZ
    TailsNZ
    Ah yeah thanks, scart sounds like the best way to go.
  5. Ozyredeye
    Ozyredeye
    Just where can you get one of these Scart cables or how does one convert one ...
    thanks Martin
  6. Ozyredeye
    Ozyredeye
  7. Ozyredeye
    Ozyredeye
    Thanks for that M.
  8. ROZ
    ROZ
    Jan 4, 2005
    120
    Hey Oz
    Did you try this?
    Did this work?
