The best TV ever
Discussion in 'General TV Discussions Forum' started by Ixon, Jul 19, 2002.
  1. Ixon
    Ixon
    Jul 3, 2002
    182
    Wigan, England
    +4
    Which TV would you vote for as being the best TV ever in terms of picture, sound & style.
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    They are all flawed.;)
  3. shaunthedude
    shaunthedude
    After having 6 or 7 tvs in one year, all replaced due to common faults my favourite is the Tosh WH4218B. Great picture for a RP. Good sound and great looks. I am very happy with it.
  4. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    I would have to go for the Toshiba XXZD26P fantastic picture. Great looking set, although not to everyones taste, and Progressive Scan. Five stars
    Paul
  5. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Mine.
    Or which ever one someone will give me for free.
  6. pi3141
    pi3141
    shaunthedude,
    Was prcing this TV up today. THinking of going down the RP route after been through th eSony scrolling bars problems. May of the RPs had really good pictures - how do you think it compares to normal CRT TVs ?
    cheers
  7. shaunthedude
    shaunthedude
    All the tvs I had before getting the Tosh rp were crt. The picture is not as crisp and the viewing angle is not as good as a crt so you will have to look at your sitting arrangments. BUT, this model has a verry good viewing angle compared to the other RPs I looked at. However, in my opinion the difference in screen size makes up for this. I use mine mainly for dvds and the picture is FANTASTIC and just as good as the crt models I had. tv programmes are only slightly worse than a crt and video is slightly worse again but still very watchable. I have a load of old bw films I taped of the tv and I can watch them without complaint. Overall I am very happy and would certainly go with RP again. I hope this helps. Anything else just ask!
  8. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,615
    Somewhere in South Yorkshire
    +6,157
    The best TV ever is probably a year or two away. It will be probably be a direct view LCD set - rather like the excellent Panasonic TX22LT2 - but larger, less expensive, and with an inbuilt DVB tuner.
    As an LCD set, it will have absolutely perfect geometry, absolutely no convergence errors, and absolutely no visible refresh rate, even when driven with a 50hz signal. It will weigh substantially less than CRT TVs and will use a fraction of the power.
    By the time it comes out, the contrast from the LCD panel will be a little better than currently available. In addition, as the above Panasonic does, it will utilise a system whereby the brightness of the backlight varies with picture brightness to increase the subjective contrast.
    If size and price aren't an issue, then the best TV currently available is probably the said TX22LT2.
  9. snake II
    snake II
    May 19, 2002
    353
    luton
    +5
    i would say the sony kv36fs70,
    the picture quality is great with the help of the 100drc the picture is awesome, the sound is also very good with crystal clear sound and its just a great tv.
    another good tv is the small bedroom size one its the panasonic tx-21ck1 the picture is good but the sound is much better you cant improve much on this model due to the fact its a bedroom size tv.
  10. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I think this is probably very tue. Nothing on the market currently does the quality thing.
    A nice arguement. I suspect 2/3 years down the line we will look back at CRT as being old hat. Plasma will be on the way out and Nigels suggestion might well be the leading technology.
    One of the most eminent research, ex ICI, said to me the other day, if you mant to make money invest in LCDs. It will be the biggest growth area in technology.
  11. Garrett
    Garrett
    Apr 21, 2001
    43,658
    2
    167
    The best thief you'll never see.
    +8,416
    Loewe Aconda, brilliant picture, and even looks good switched off.
    Wouldn’t mind a large plasma when the prices come down a bit more.
  12. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,120
    Leicester
    +49
    Philips widescreen 32PW6332.
    Unfortunately I got rid of it thinking a Panasonic would be better,how wrong I was.
    My current Philips widescreen 32PW6006 comes very close though.
  13. LV426
    LV426
    Jul 14, 2000
    13,615
    +6,157
    Which is why, at present, my advice to anyone looking to buy is, buy a Dinosaur CRT cheap and be prepared to ditch it in 2-3 years when something really new (which may be LCD) hits the streets.
