the best player for sub £200
Discussion in 'Blu-ray & DVD Players & Recorders' started by Daddy k, Oct 27, 2005.
  1. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    ok guys if any ones bored or just likes to help out then here goes.
    i think for xmas im gona upgrade my dvd player.
    you can read my current setup on my sig.
    my tv does have component and dvi and would prefer to use one of these however i will also be getting xbox 360 which will also have to use one of these. prob component as my existing xbox is. so perhaps a good switcher? but cheap!!!!!
    my requirements are:
    play all formats ie svcd etc (copies/backups)
    sound must be thru digital connection to my amp
    other than that i just want the best processing n picture available for my money (which yeah isnt much)
    especially as its going to a plasma so every lil helps with picture quality.
    thanks for taking ur time to help guys :thumbsup:
  2. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    wow thats a lot of choice ;)
  3. mjcairney
    mjcairney
    Oct 26, 2003
    7,319
    2
    137
    Airdrie, Scotland
    +1,105
    If you can get your hands on one, go for a Pioneer DV-575 - great machine, and you'll get change from your £200 to buy some new disks.
    Cheers,
    Martin.
  4. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    cheers ill check it our rite now lol
  5. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    any body here using DENON DVD1720
    or got any good reports?
  6. mark88
    mark88
    Oct 25, 2004
    878
    +23
    I just bought a multi region Denon DVD-1920 from weymouth hifi for £199 including free delivery! Bargain.
  7. pmc
    pmc
    Oct 18, 2004
    1,414
    +104
  8. logiclee
    logiclee
    Aug 9, 2000
    1,760
    116
    Notts, UK.
    +782
    Another vote for the Denon 1920, you should pick one up online for under £200
    Lee
