The best Panasonic connection?
Discussion in 'General TV Discussions Forum' started by Neal, Mar 6, 2002.
Tags:
  1. Neal
    Neal
    I have Telewest Pace digibox conencted to plasma Panasonic 42" via RGB scart to VGA converter and my Denon 2800 DVD connected direct to the screen with component cables (and Svideo - just to give me more aspect conrtrols). The receiver is the Denon 3802 with Kef eggs. Is the best way to have it all set up? Is it possible to run the DVD through the converter too? Would that be better tha component? Would the Prog scan be affected for Region 1? Anyone know?
  2. philipb
    philipb
    Mar 6, 2002
    2,058
    63
    Swindon
    +153
    Your present arrangement is probably best. I have recently installed J S Technology's RGB to S-Video converter, and that gives via the S-Video input virtually identical picture quality to the RGb to VGA converter. I prefer the S-Video on my Daewoo because there is distinct combing on horizontal motion via the VGA input.
    As soon as the RGB to component converter becomes available then i shall go for that. The component input on the Daewoo is by far the best quality - driven by a Sony 9000ES DVD it produces top class images.
  3. philipb
    philipb
    Mar 6, 2002
    2,058
    63
    Swindon
    +153
    Neal - sorry forgot to add. On my plasma the progressive only works via the component input - assume the Panny is the same.
