if you're rocking an intel cpu, and NOT overclocking, they're gonna draw max 100w (95, ok..). cd, hdd, mobo, etc dont draw much at all..
video card, most of the power hungry ones are in the 250-300 watt range. You CAN power most single card systems with a 500, but I tend to prefer a bit of overhead. In general, you should be able to power any card you can cram in there.. "should".
depending on how much performance you need.. it might be worth looking at last years cards or even a few years old cards. If you take the r270 vs. say a hd6970 (came out in 2012), there isnt much performance difference but the hd6970 would be 1/2 the cost. In crysis at 2560x1600 4xAA, the 6970 is a full 4.3 fps slower... so you do lose some performance, but not much. The HD7970 actually out performs the r270x, and can be found for approximately the same price new.
